Author Topic: How long will you ride WOT?  (Read 10536 times)
manimal
  • 2013 Super 8 150
Re: How long will you ride WOT?
« Reply #30 on: November 14, 2014, 05:31:44 PM »
Nice, same here. My commute is like 45-55 for like 20 miles.
How far do you travel?
13 miles, each direction (26 miles 'round trip). There are 3 expressways I travel throughout my commute, 1 posted at 45mph, the other 2 50mph posted. There are traffic lights along the way on each of the expressways.
In the morning and also depending on timing between green lights, is where I consistently travel at a higher rate of speed (50 - 55mph on the speedo), since traffic is lighter.
« Last Edit: November 14, 2014, 05:36:24 PM by manimal »
~Daren
California (Nor*Cal)
manimal
  • 2013 Super 8 150
« Reply #31 on: November 14, 2014, 05:35:13 PM »
Make sure you guys that are driving the 150's that far that hard check your oil regularly, like once a week. I've had two people blow up super 8's from long extended high speed because they didn't check their oil and it was bone dry. The air cooled gy6 consumes a bit of oil even when everything is in good shape.
Thanks for the heads up :thumbup After turning the 1k mark, and due to several threads I had read about checking the oil, sure enough, I needed to add about 50cc of oil. My last oil change was @600 miles.
« Last Edit: November 14, 2014, 06:32:14 PM by manimal »
~Daren
Amaro321
« Reply #32 on: November 14, 2014, 08:09:25 PM »
Man, travel safe brother. Makes my travel seem easier lol
« Last Edit: November 14, 2014, 09:58:49 PM by Amaro321 »
Amaro321
« Reply #33 on: November 23, 2014, 04:57:01 PM »
I actually have been finding myself having to travel at higher speeds recently. I wonder if there is a transmission setup that would be preferable in this situation.
« Reply #34 on: November 23, 2014, 07:28:46 PM »
You have a 150 right? Get the Dr. Pulley for gy6 it kicks ass. I've found then as cheap as $90.
« Reply #35 on: November 23, 2014, 09:28:54 PM »
That's choice #1
#2 is go 2 gram heavier on your rollers. That will take about 100-150 rpm off any given speed. It will slow down take off but greatly help highway rpm.
You might want to look into up gears for the GY 6 engine as well. I'm sure they are available, but not sure if the fit in a Kymco. a little looking around the web might answer that one.
Amaro321
« Reply #36 on: November 24, 2014, 11:26:23 PM »
Yes sir I do. Nice!! I love finding things out that I had no idea about lol I'll look into this sir thank you.
That's choice #1
Great!! And I was wondering about the weights. I'll try a bit heavier weight with a Dr Pulley setup. Once I get the parts and all that I'll post up!! 😊 maybe next paycheck. Even though the cold weather is going to suck.
« Reply #37 on: November 25, 2014, 01:25:13 AM »
If you order the Dr. Pulley variator, keep in mind it doesn't come with weights so you should order a set of 12-14g sliders. If you get a slightly stiffer clutch spring you can run heavier weights and not lose hill climb power
