Author Topic: Condition that cause oil out of overflow tube ?  (Read 2506 times)
Chris0381
« on: May 16, 2014, 11:53:44 AM »
What condition cause oil to drip out of the clear overflow tube extending down the bottom of the scooter below the carb. I had a drop or 2 not sure if its normal or not. Ill keep an eye on it. The oil was green and quite viscous.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
AMAC1680
    • SEGS4VETS
Re: Condition that cause oil out of overflow tube ?
« Reply #1 on: May 16, 2014, 12:13:15 PM »
Normal. Small amounts of oil are ok and just part of normal operation.
Someone with a better ability to tell you exactly why it happens is sure to follow up !
Be Big,
AMAC
www.SEGS4VETS.org
2017 Lance Cali Classic 200i
2013 SYM RV200
2013 Kymco Downtown 300
2010 Lance Cali Classic-sold
1973 VW Dune Buggy
1974 VW Meyers Manx
Chris0381
« Reply #2 on: May 16, 2014, 03:04:26 PM »
TY
Good to know as there is nothing about that in the owners manual.
Smooth Boss
Polini Variator
#95 Main Jet
DMblues01
  • 2012 Kymco Super 8 150
« Reply #3 on: May 16, 2014, 10:04:20 PM »
TY
There's not much about anything in the owner's manual!
That's why the forum is awesome. Any question you have, someone here will know the answer.
And if nobody here knows, then it's just broke so go buy another scooter!  ;D
Roxana, IL
Yoda is my spiritual leader.
« Reply #4 on: May 17, 2014, 02:19:39 AM »
green oil?
Chris0381
« Reply #5 on: May 17, 2014, 11:27:21 AM »
green oil?
Yes it was green, may have been gear oil. I just replaced the gear oil last night.
Smooth Boss
Polini Variator
#95 Main Jet
pmoneysuper850
« Reply #6 on: June 13, 2014, 06:15:35 PM »
i just cleaned my scooter and wiped up all the leaked oil ( even used plastic zip ties).  a few days later the leaks are back.  i guess it is common !
stay safe riding!
« Reply #7 on: June 14, 2014, 12:19:59 AM »
It is excess gear oil. I am guessing you did not measure the oil amount you installed but rather filled it up till it weeped out the top vent plug.
Take out about two tablespoons worth, and the weeping will stop.
Chris0381
« Reply #8 on: June 14, 2014, 10:38:22 AM »
Seems after replacing my gear oil and putting in a carefully measured amount, the dripping has stopped.
Smooth Boss
Polini Variator
#95 Main Jet
« Reply #9 on: June 14, 2014, 06:02:13 PM »
Funny how Kymco can get a few things right. At least they know how much gear oil is correct.
pmoneysuper850
« Reply #10 on: June 23, 2014, 05:00:13 PM »
will do!  thanks
Chris0381
« Reply #11 on: July 28, 2014, 08:51:40 PM »
Just want to update this.
Oil is not flowing out of that tube as the tube is connected to the bottom of the carb it wouldn't eject oil. This I believe is caused by my sloppy filling of the 2t oil reservoir.
« Last Edit: July 31, 2014, 01:40:39 PM by Chris0381 »
Smooth Boss
Polini Variator
#95 Main Jet
