Author Topic: Something to prevent rusting of screws?  (Read 2118 times)
kimura
  • 2012 super 8 50cc 2t
« on: May 16, 2014, 02:26:58 PM »
I lost the caps that go on the screws, see attached pic.
Is there anything I should spray on there to prevent those screws from rusting?  maybe some WD-40?
Chris0381
Re: Something to prevent rusting of screws?
« Reply #1 on: May 16, 2014, 02:29:36 PM »
Another flimsy setup. I see those caps can easily be lost. Replace with stainless steel or use a hot glue gun to fill the cavity. Hot glue can easily be pried out when time comes to remove screws.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
kimura
« Reply #2 on: May 16, 2014, 02:42:19 PM »
thanks for the reply,
but I don't have a hot glue gun, I'm looking for a cheaper alternative.  would wd-40 not be good enough.
1 month of riding, 450miles logged, I've lost 3 screws, 2 caps, and its leaking oil.  the struggle is real but damn I love this little scoot. lol
Chris0381
« Reply #3 on: May 16, 2014, 02:45:35 PM »
WD -40 applied now and then should help. Those caps aren't water tight to begin with as they are just cosmetic and I would recommend wd-40 even if you still have the caps on.
Smooth Boss
Polini Variator
#95 Main Jet
AMAC1680
    • SEGS4VETS
« Reply #4 on: May 16, 2014, 04:42:37 PM »
Try clear or black silicone caulk. Clean with a solvent before applying.
Be Big,
AMAC
www.SEGS4VETS.org
2017 Lance Cali Classic 200i
2013 SYM RV200
2013 Kymco Downtown 300
2010 Lance Cali Classic-sold
1973 VW Dune Buggy
1974 VW Meyers Manx
boo
WD-40 no
« Reply #5 on: May 16, 2014, 05:28:20 PM »
WD-40 is good for cleaning or dispersing water.
Not good as a rust preventive. I found that out the hard way.
Clear chalk is a good cheap way to go.
300GTI black
Pro 2A - member GOA & NRA
« Reply #6 on: May 18, 2014, 10:04:41 PM »
Best thing is to replace all the mounting hardware with Stainless nuts/bolts/washers whatever.
It will cost you 2-3.00 to swap a few each week.
It's one of the best spent improvements.
mrmike
  • Syuracuse, NY
« Reply #7 on: May 18, 2014, 11:45:39 PM »
  Forum member MASSCOOT recommended a product called Corrosion X to me. Find my post "Finally Done" dated April 17, 2013 in the GT300I column. I got a can and it seems to work well. The site is posted in a reply by MASSCOOT to my post.
« Last Edit: May 18, 2014, 11:52:16 PM by mrmike »
08087
  • 09' Peoples 200, NJ
« Reply #8 on: May 19, 2014, 12:53:45 AM »
Stainless screws.
lbmcconnell
« Reply #9 on: May 22, 2014, 03:24:55 PM »
WD-40 is water soluble.
ophelia
« Reply #10 on: May 22, 2014, 03:36:57 PM »
Another vote for stainless fasteners.
2011 Kymco Downtown 300i
MoToFaLcon
  • I Fly....
« Reply #11 on: May 23, 2014, 01:05:22 AM »
Maybe duct tape or play doe?
WTF, i have a Ninja 650!!
Momma bear
« Reply #12 on: May 25, 2014, 12:18:00 AM »
You may find the same caps inside your top case . I did and replaced them. Throw a little Vaseline one the screws.
Ride safe
People300i
« Reply #13 on: May 25, 2014, 01:16:09 AM »
The plugs are only a couple bucks each. Now leaking oil, that should be your primary concern!!!!
kimura
« Reply #14 on: May 26, 2014, 09:43:17 PM »
thanks for the replies guys,
it stopped leaking oil since I've left the oil container under the seat half full.
I've been using a few drops of this bicycle chain lubricant to prevent any rust, lets see how it works out.
