Author Topic: Ignition block stripped, need colours (pic inside)  (Read 820 times)
iwbbnis
« on: May 18, 2014, 01:01:20 PM »
Hello fellow Kymco owners :)
Kymco Agility 125 City (2012)
Just recovered it after it was stolen a few days ago and they've ripped all the wires of so I don't know what goes where.
I plan to solder the wires back on, the block itself is fine and I don't wanna buy another because it's the 2nd ignition block on the bike, trying to save money :)
Could someone tell me what colours each tip has, I can work out the rest, Thanks, Tom
Re: Ignition block stripped, need colours (pic inside)
« Reply #1 on: May 18, 2014, 04:43:55 PM »
Try this...
iwbbnis
« Reply #2 on: May 18, 2014, 05:25:14 PM »
Thanks for the reply, but it's a different block.
« Reply #3 on: May 18, 2014, 07:42:27 PM »
Dumb question... Did you try the manual? We might have one in the Kymco Links thread.
I would also suggest try the basics... With an Ohm Meter find the power contacts. Then you can find the ground, and kill wire cause they will read common when the key is off. That leaves one wire, and the solder join will locate that for you.
