Author Topic: Extra fuel capacity  (Read 1808 times)
2wheelfun
Extra fuel capacity
« on: May 18, 2014, 10:28:20 PM »
Found out a 1 gallon red fuel tank from AZ fits perfectly in the top case, extra 80miles without worrying about the next gas station.
Re: Extra fuel capacity
« Reply #1 on: May 19, 2014, 02:05:55 AM »
Do you drive around w/ fuel in the trunk of your car too? :o
« Reply #2 on: May 19, 2014, 02:25:25 AM »
Well, that is a thought, but I'm thinking that would make me uncomfortable.
A) seems a bit of weight high up, and way out on the end,  of a scooter's center of gravity
B) maybe stopping for gas every 75 miles might give the keester a welcome break
C) might it be better to keep a large fuel can in the garage & fuel the scoot before each ride?
D) is it an actual 'tank' for safely transporting gas - or a plastic gas can?
« Reply #3 on: May 19, 2014, 03:31:32 AM »
You could have a polypropylene  fuel cell made. I use Sealand for custom marine tanks, and they are reasonable. Separate fill, and vent systems. A dpdt for fuel senders, and a separate manual petcock. Maybe 2-3 hundred complete.
2wheelfun
« Reply #4 on: May 19, 2014, 10:30:12 AM »
Good idea zombie but I'll stick with an $8 1 gal tank. Here the fun riding is out in the sticks where there's less traffic and no gas stations. 1gal of water weighs 8.5 lbs and gas is lighter so the weight isn't an issue at all.
« Reply #5 on: May 19, 2014, 12:50:18 PM »
A hot plastic box full of pressurized fuel vapor is my concern. Fuel vapor is heavier than air so think about what is directly below the box... Your arse, and then Ignition.
AMAC1680
    • SEGS4VETS
« Reply #6 on: May 19, 2014, 02:35:25 PM »
Well put.
Although we don't consider vapor issues with cycles the enclosed areas of a scoot should be of at least some concern. Where the "open" body of a cycle allows gas vapor to dissipate that may not be the case with a scooter. With no spark protection on any of the electrical stuff a spark and some vapor could be bad news.
Those with marine interests get this better than most. A tablespoon of gas in an enclosed bilge can lead to disaster. Can that happen on a scooter? Maybe.
Be Big,
AMAC
www.SEGS4VETS.org
2017 Lance Cali Classic 200i
2013 SYM RV200
2013 Kymco Downtown 300
2010 Lance Cali Classic-sold
1973 VW Dune Buggy
1974 VW Meyers Manx
TroutBum
  • 2012 Like 200i (sold)
« Reply #7 on: May 19, 2014, 03:42:14 PM »
MSR fuel bottles are one option especially if you're considering carrying in an enclosed space.  Another option are the Kolpin fuel packs used by long distance scooter riders mounted on their front our rear racks.
2wheelfun
« Reply #8 on: May 19, 2014, 05:00:31 PM »
You guys have me thinking twice about my idea. Maybe that tank isn't sturdy enough. Tough little tank, but the spout/trigger is the weak link.
« Last Edit: May 19, 2014, 05:02:26 PM by 2wheelfun »
« Reply #9 on: May 19, 2014, 11:15:36 PM »
It's only a matter of heat, and ventilation that I am thinking of. Perhaps an aluminum fuel cell?
http://www.summitracing.com/search/part-type/fuel-cells/capacity/1-gallon
I buy alot of stuff from these guys, and the service/value are top shelf.
