Author Topic: how to set up throttle position sensor  (Read 2107 times)
csor.zola
« on: May 19, 2014, 11:42:12 AM »
hi there,
does anyone know how to adjust tps on my kymco agility 125. the manual does not say anything about it. i took it off couple of day ago and now m having difficulty to put it back correctly.
Re: how to set up throttle position sensor
« Reply #1 on: May 20, 2014, 05:02:22 PM »
See your post on "carburetor question".
csor.zola
« Reply #2 on: May 20, 2014, 08:33:43 PM »
If anybody would be interested in how to adjust TPS on kymco agility I have found half of the answer. Firstly, two thing has to be checked 1. resistance and 2. voltage and unfortunately I don't know the voltage setting. Which is the main thing. Anyway....
The resistance should be 5Kohm (-+30%) between the black and green wire and the same between the red and green wire WHEN THE THROTTEL FULLY OPEN.
I am still looking for the voltage setting. If anybody knows....pls.
But someone told it should be 0.5V
