Author Topic: What did you do to your DownTown today?  (Read 177060 times)
Re: What did you do to your DownTown today?
« Reply #240 on: November 15, 2015, 11:04:19 PM »
Removed air filter cover and plastic cvt cover expecting both to be packed solid with ladybugs! None in either one! Every other spot is FULL of the things. Removed metal cvt cover to inspect new belt. Little bit of black dust and belt lookin' good! Put it all back together and went for a short ride in the 65 F weather.
mousejunks
« Reply #241 on: November 17, 2015, 03:34:19 PM »
Past month:
- Fixed sticky indicator switch (blob of solder on lever)
- Fixed sticky headlight switch (WD-40 on switch)
- Installed 55W driving lamp
- New windshield replaced old translucent one.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
donjack
« Reply #242 on: November 26, 2015, 10:49:26 PM »
hello all, I just had to tell you guys about these LED headlight bulbs, I put them into the main beams and they are brilliant!!
http://www.ebay.co.uk/itm/1-Set-8000LM-80W-H7-COB-LED-Car-Headlight-Fog-Lamp-Conversion-Bulb-Beam-Kits-/401024714278?hash=item5d5eef8626:g:vGoAAOSwu-BWQUU7
I had the standard halogens in but they didn't match the HID's on the dipped beam, but now they do!! well impressed!!
kneeslider
« Reply #243 on: December 22, 2015, 06:12:41 AM »
Replaced rear brake pads on my DT 200.
They were the factory fit ones, got 22280km out of them.
2019 Yamaha X-Max 250
« Reply #244 on: December 22, 2015, 07:11:13 AM »
Donjacks headlights ,   looks great, love them!    what happened to the LED spot lights ,  I bought a set too,  I mounted the on the side panels , looks like I have 4 lights in a row, I like the way they light up the road,
donjack
« Reply #245 on: December 23, 2015, 08:24:26 PM »
De Dee, yes they do look good thanks!!
here is a photo, I had to adjust the camera so that you can see them.
the spots are at the bottom of the picture.
cheers,
Don.
« Reply #246 on: February 23, 2016, 11:45:33 PM »
  13 F. this morning,  went for a little ride,. 1/2 hour later got home just a little chilly, but it was nice ,only 4 more weeks of cold weather,
DownTownMOD
« Reply #247 on: February 24, 2016, 03:41:23 AM »
Hi de dee- I gotta ask you- did you only buy the led bulbs and changed them? Do they fit and work with no other modifications?
Thanks
« Reply #248 on: February 25, 2016, 10:02:11 PM »
  I bought a kit with the lights, they need the starter kit to turn them on,  that is the HID light kit ,  if you buy LED.s just the lights I have not tried LED head lights as yet,  soon this spring, I heard they have better light spread, and better distance,
ktienation
« Reply #249 on: February 28, 2016, 07:14:52 PM »
Dee dee, i have one question as you have mounter Xenon lights - do they relly give better vision (i assume they are mounted in the projector lights (with lens). I observed, that my light is quite poor with the HIDs on, i thaught that maybe the mirror are weared of, but they dont. When i had a closer look (i put a sheet of paper like 15 inches from the lamp i found out, that as the HID bulbs are longer than standard halogens, they are so close to the lenses, that you can literaly see the top of the bulb in the projected light (a weaker spot shaped as a bulb - seen from above).
« Reply #250 on: February 28, 2016, 08:51:30 PM »
  Ya I found out that the HID lights do not match the reflection of the lens on our downtowns, don jack seems to like the LEDS better, by the pictures they have improved lighting ,  and a whiter light, they project light off the side of the bulbs, and use the shape of the lens better,
« Reply #251 on: February 29, 2016, 10:25:10 PM »
  removed the snow and ice so I will be ready for a warm day, and go for a ride with out the tractor snow blower, 3 weeks to go for first warm days,.
« Reply #252 on: March 03, 2016, 07:36:40 PM »
just finished removing the snow again,  27 C  below this morning, that's 12 F below ,  we are supposed to get some warm weather next week above freezing for a few days, I may get a ride in ,  and my LED lights should arrive in the mail,.
donjack
« Reply #253 on: March 03, 2016, 10:28:48 PM »
De dee, -27c!! The UK GRINDS to a halt anything below -2c!!  ;D ;D ;D
That IS bloody cold!!
Have to put my jacket on now, it's about +6c here!!   ;D
I hope you like the leds as much as I do.
Cheers,
Don.
« Reply #254 on: March 12, 2016, 09:30:42 PM »
  There is nothing like working on the side of a building installing steel venting at 20 below 0 F.  40 feet high,
been there and done that,.    to finish off a job so I could get paid,
