Author Topic: What did you do to your DownTown today?  (Read 160350 times)
Re: What did you do to your DownTown today?
« Reply #315 on: May 02, 2016, 08:15:03 PM »
some one called it SNOT  TUBE,.
  looked it up ,.   F13 air cleaner
 V tube assy.  1737A kudu-900    $ 17.50,.     it comes with two clamps and hose ,with plug
kneeslider
« Reply #316 on: May 03, 2016, 09:09:35 AM »
Changed my rear tire once again. She is now at 29000kms.
This morning she was hard to start, finally she did after long cranks while playing with the throttle.
Any idea why this was so? Last rode her was just 48hrs ago.
2019 Yamaha X-Max 250
« Reply #317 on: May 03, 2016, 01:48:10 PM »
Last valve check?
  "    plug    " ?
TANWare
« Reply #318 on: May 03, 2016, 06:17:54 PM »
Still waiting on the LED strips, but took it out for a ride in the light rain. Amazing the protection compared to the open bikes I am used too.
ScooterWolf
« Reply #319 on: May 03, 2016, 10:47:51 PM »
5000 Miles. Another milestone while still under one year of riding the DT.
- Wolf
kneeslider
« Reply #320 on: May 04, 2016, 02:59:41 AM »
Last valve check: Never
Last plug change: About 4000km ago.
Last valve check?
  "    plug    " ?
Snorvey
« Reply #321 on: May 07, 2016, 12:17:06 PM »
Re: The Fuel Filler Cap
With these bikes the gas system is sealed so you need this to work
How true. I bought a 'universal' fuel cap today from the local motor factors. What a difference - particularly at low speed, where previously  it was very jerky in slow traffic.
Never having ridden an automatic before, I just thought that's how it was.
Not a bad fix for less than a tenner.
Cheers!
TANWare
« Reply #322 on: May 07, 2016, 08:31:47 PM »
Yeah, these bikes have a sealed fuel tank system. They will not run properly if the seal does not exist.
Snorvey
« Reply #323 on: May 08, 2016, 10:54:48 AM »
Yeah, these bikes have a sealed fuel tank system. They will not run properly if the seal does not exist.Yeah, these bikes have a sealed fuel tank system. They will not run properly if the seal does not exist.
Well thanks again for your advice - if I had not come on here, I would have just have lived with it
it might also be worth a thought to others who experiencing poor low down/part throttle running to check that the seal on their fuel cap is working properly.
Oh, and I picked up a service manual from offering a download here, so that's an added bonus.
Well it's a beautiful day, but first a touch of lunch, a bt of MotoGP and away out for a run in the courtryside.
Cheers.
mnpugdog
« Reply #324 on: May 09, 2016, 07:23:14 PM »
Not really a mod to the DT but got a Go Pro Session for the helmet. Now the next time I get cutoff at least it will be recorded. Now to get a cam for the car for the samething.
mousejunks
« Reply #325 on: May 12, 2016, 12:59:11 PM »
morning chaps, jimboe mentioned the crankcase breather, i don't know whether this is it or not, but when i give mine a service, there is always a good bit of s**t in it, it's is like thin cloudy oil!! unplug it and drain.
if anyone can enlighten me as to what its call!!
It's a called a ventilation tube assembly (part 1737A-KUDU-900) and is used to prevent oil from the crankcase blow-by tube (which empties in the air box) from contaminating the air filter.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
« Reply #326 on: May 13, 2016, 11:44:55 PM »
  70,860 Km.   time to change tires again,   Oil , gear Oil, and check every-thing,  left to do, check the valves, and I will be good for the summer,  I installed city grips rear tire 150/70  13  and 120/ 80  14 power pure front tire,.  shell rotunda T6 10 W40 Oil,   cleaned the variator, checked sliders, checked belt 23.4 mm wide ,  looks like new,. cant find minimum size for belt, just change every 20,000 Km. (12,000 ) miles,.  ( Mitsuboshi size 25.2 mm. X 1004mm.  new belt ),.  most belts I have bought are 24 mm wide,.
pipster326
« Reply #327 on: May 14, 2016, 11:19:41 PM »
de dee, I think I am going to change my tires soon. I'm curious as to why 2 different models of tires ? I still have the factory maxxis' . I'm trying to get as many opinions as I can before I make my purchase.
     Rich
TANWare
« Reply #328 on: May 15, 2016, 12:22:13 AM »
I just turned 6,000 miles today. I have to say this is just one great bike. To me it feels best at highway speeds of 55 mph or less but it settles in fine at 65 mph plus too. it is just more a relaxed ride at the lower speeds. Having the topbox for shopping works wonders too. being able to carry 2 gallons of milk and a couple of bags makes it great for small store runs.
my next project looks like finding a good sidebag system.
mnpugdog
« Reply #329 on: May 16, 2016, 01:37:36 AM »
When you find one TAN let us know. With the topbox I have been able to carry 2 12 packs of soda, a gallon of milk and 3 bags of stuff between that and under the seat
