Author Topic: What did you do to your DownTown today?  (Read 176618 times)
pipster326
Re: What did you do to your DownTown today?
« Reply #435 on: August 28, 2016, 09:50:44 AM »
Don't even bother taking the seat bucket out, to access the plug. If you put your hand up under by the side stand and look through the vent you can change it that way. Still a PITA. Be prepared to kneel or lay on the ground, though. Not an ideal location
pipster326
« Reply #436 on: August 28, 2016, 11:07:37 AM »
Wasn't able to take the DT300, to Niagara Falls last week :-(  so I had to settle for these: the falls on the Passaic river , near my home
Snorvey
« Reply #437 on: August 28, 2016, 03:38:17 PM »
Five English pounds and one 16mm deep spark plug socket later and problem solved. Spark plug removed, cleaned and gapped in a matter of minutes.
I'm definitely a 'seat tub out' type of guy though. Although I could reach the plug, I didn't have any kind of purchase. Besides, I wanted to adjust and lube the seat release cables and disconnect and secure the underseat light.
Life is easier when you have the right tools! Apologies for the earlier rant.
Quick question while I'm here. I've read that some folk take the muffler off when removing the real wheel - presumably to allow better access to the rear wheel spindle... But the suspension mounts look very accessible. Is it worth removing the retaining bolts and letting the wheel drop down? Just a thought.
« Reply #438 on: August 28, 2016, 09:44:46 PM »
Won't drop that far, Snorvey. Sliding the muffler off is the easiest since I did it both ways.
Snorvey
« Reply #439 on: August 29, 2016, 09:19:14 AM »
Thanks for that Karl - much appreciated.
« Reply #440 on: August 29, 2016, 09:54:45 AM »
when you take off the muffler you will see you have to take it off to get the wheel off,. the wheel slides off the axel,  I remove the two shocks bottom bolts and let the wheel drop down ,to give room for the wheel to slide off,  when it is done check the air intake at the FI.  to make sure it did not pull off,
mousejunks
« Reply #441 on: September 04, 2016, 09:58:57 AM »
According to the service manual, first remove the mudguard, then the muffler, caliper, shock absorber bolt, rear fork then the axle nut.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
firestorm916
  • Kymco Rule!
« Reply #442 on: September 06, 2016, 10:47:50 AM »
Washed it for the first time, and took it for a spin up the road...
Previously; rsx100, cb350s, klr250, diversion600, vfr750fm fzr400rr tzr2503xv, fireblade900, gsxr400r, tdr250 gsxr600sradx2 tl1000s xr600, tzr250sp3xv gsx400s katanax2 Sherpa250, cbr400Tri-arm, 916 Biposto gsxr600K1 tl1000s, fzr400, rgv250x2, FJ1200 Sherpa250, cbr400 tri-arm Firestorm..now Kwak J300
Snorvey
« Reply #443 on: September 06, 2016, 11:10:38 AM »
Looks like fun.
Since the weather turned better, I've been commuting the long way round to work lately.  You don't half feel better when you get to work...the oy problem is you sit looking longingly  out the window at the scoot and the sunshine and ever get any work done.
Got my pin spanner for the rear shocks in the post today, so I guess I'll be fiddling around with the suspenders at the weekend
« Reply #444 on: September 06, 2016, 08:03:26 PM »
I am 6 foot ,  220 lb.s   and I set my shocks at #3,.
Snorvey
« Reply #445 on: September 06, 2016, 10:20:23 PM »
I'm a  stone a and a half lighter and a couple of inches shorter than you and my shockers have been set to max since it bought the bike. It's been a bumpy ride and it can't wait to soften things up. I'll start at 3 and go from there.
donjack
« Reply #446 on: September 06, 2016, 10:35:54 PM »
5' 8" 13St
Started on 3
Now on 5, i love the sportier feel!! But, each to there own!
kneeslider
« Reply #447 on: September 07, 2016, 01:01:16 AM »
1 & 2 are hopeless, the scooter doesn't stay stable in corners.
3 is just acceptable.
4 & 5 are best for that extra stability in corners but yes, you lose out on the ride comfort.
Depends what you're after.
2019 Yamaha X-Max 250
« Reply #448 on: September 07, 2016, 01:05:36 AM »
when you have a 83 year old butt, you go for comfy,.
« Reply #449 on: September 07, 2016, 11:11:01 AM »
Remember the RULE....dedee...no pix it didn't happen.
For all we know...you could be 23.
