Author Topic: What did you do to your DownTown today?  (Read 176616 times)
Re: What did you do to your DownTown today?
« Reply #450 on: September 08, 2016, 12:17:03 AM »
when scooter wolf gets here,. will send a moony
Snorvey
« Reply #451 on: September 10, 2016, 02:16:13 PM »
Shocks set to 3.... Not guy time to go out just now, but I'll see how things are tomorrow. The exhaust side shock adjustment isn't the easiest to get to eh?  -
Snorvey
« Reply #452 on: September 11, 2016, 09:18:34 PM »
No.3 setting on the shocks = soooooo much better.
ScooterWolf
« Reply #453 on: September 12, 2016, 02:15:21 AM »
De dee, looking forward to getting there in one piece.
- Wolf
« Reply #454 on: September 12, 2016, 04:30:49 AM »
- Wolf
are you coming in on HW. 81
ScooterWolf
« Reply #455 on: September 12, 2016, 05:47:48 PM »
Yeah, I'm taking I-81 as a straight shot through upstate NY, then crossing into Canada at the Thousand Islands. Then it's 401 to 416 and into Ottawa.
- Wolf
kneeslider
« Reply #456 on: September 15, 2016, 05:44:01 AM »
To adjust your rear shock, place you scoot i on its center stand, that lifts the weight off the rear hug, hence making it easier to adjust the shock preload.
2019 Yamaha X-Max 250
Snorvey
« Reply #457 on: September 15, 2016, 11:32:54 AM »
Hi
Yeah, did all that and managed to get it adjusted in the end. Maybe my pin spanner wasn't quite the right tool for the job as I had to hook it in at quite a steep angle on the exhaust side. The other side however was a piece of cake.
« Reply #458 on: September 17, 2016, 05:45:46 AM »
Modifying a variator drive plate where the sliders slide in and out.  test run # 3 getting better,.  ( lower RPM. ) more grinding tomorrow, after midnite   I mean today,.
« Reply #459 on: September 18, 2016, 11:17:14 PM »
  Finished grinding to the template from the first variator plate,. test ride # 4 very good ,. took a little ride 150 miles and now I am happy,.  waiting to show scooter Wolf the variator so he can take pictures and post them,.
kneeslider
« Reply #460 on: September 19, 2016, 10:36:40 AM »
Just a note of caution:
Do not use Goldfren brake pads. They eat into the rotor something fierce. I have gone thru two set of Goldfren, the AD and S33. About 25,000 kms off those two sets and my rotor is heavily grooved and past min thickness.
Spoken to my local Vesrah distributor and he too mentioned he has customers that were complaining of the same thing using Goldfren.
My Goldfren S33 (HH rated) front brake pads arrives yesterday and I installed them when I got home.
The front pads for the DT200 uses the Goldfren model code 022. As long as it's 022, it'll fit the scooter.
During the install I noticed you do not need to remove the caliper, you just need to:
1) screw out the pad locator pin, then pull it out and clean it
2) The pads will fall out, if not give the sliding caliper a shake to push in the pistons
3) test fit the pads to make sure they fit properly. Pushing the sliding caliper in towards the disc will help push the pistons further back into the caliper
4) fit in the new pads so the end sit in the notch for of the pad retainer, align the pads so the locator pin can slide back in
5) screw back in the locator pin. Use some locktite
Done.
Snorvey
« Reply #461 on: September 19, 2016, 07:38:00 PM »
I found a couple of videos (in Spanish, but they seemed straightforward enough) on yootoob which demonstrated how to reset the Downtown.
Turn on bike, count to ten, open throttle & count to ten, close throttle and count to ten after which you should see two flashes of the orange engine warning light to confirm all is done.
I don't get the flashes.  What's gone wrong?
Cheers!
ScooterWolf
« Reply #462 on: September 21, 2016, 12:09:22 AM »
Made it to Canada!
12 hours and only 9 gallons of gas! Did a lot of shooting with GoPro and Drift cameras. Messed up a lot of things, but really was shooting on the fly, and will correct any mistakes I made shooting the way back. The drive was incredible! The fatigue feeling I often get when I drive our students up in a 12 passenger van is gone. Never happened. Yes, I’m tired, and saddle sore, but the bike handling was amazing. Average speed -- between 65 and 75. Great weather. Great traffic.
Looking forward to the rest of week with better energy, and now a bike to have around the city.
- Wolf
pipster326
« Reply #463 on: September 21, 2016, 07:20:36 AM »
Wolf, glad to hear that you made it safely. Enjoy your trip and have a safe ride back.
donjack
« Reply #464 on: September 21, 2016, 07:53:34 AM »
glad you arrived safely, what a ride out wolf!!! epic!! was your little trip about 800 miles?
send my regards to De dee!
cant wait for the pictures.
have a good trip and ride safe home.
cheers,
Don.
