Author Topic: What did you do to your DownTown today?  (Read 176617 times)
kneeslider
Re: What did you do to your DownTown today?
« Reply #465 on: September 24, 2016, 10:58:04 AM »
Got my new front tire mounted.
2019 Yamaha X-Max 250
Snorvey
« Reply #466 on: September 24, 2016, 11:13:14 AM »
That looks quite well worn.
What's the legal limit in your country (question to everyone)?
In the UK, the legal limit of tyre tread depth in the UK for motorcycles over 50cc is 1mm across ¾ of the width of the tread pattern and with visible tread on the remaining ¼.
kneeslider
« Reply #467 on: September 24, 2016, 11:21:23 AM »
In Malaysia the police do not seem to bother how worn your tires are.
I guess it's up to the individual what they think is the wear limit.
kneeslider
« Reply #468 on: September 24, 2016, 11:41:50 AM »
Saw these two at the Kawasaki Showroom.
ScooterWolf
« Reply #469 on: September 24, 2016, 08:33:09 PM »
Thanks for the well wishes everyone. Just got off the phone with De Dee and will be meeting him at his place tomorrow.
- Wolf
Re:?finished tank of gas from day with scooter wolf
« Reply #470 on: September 27, 2016, 10:51:15 PM »
  ran it dry about 1000 feet from the gas pump],.    404.8 km.    12.58 liters to fill it,.  riding at 50 MPH.  for most of the way,. only 50 miles at 75 MPH.
ScooterBroGuy
« Reply #471 on: September 29, 2016, 09:31:21 AM »
thats pretty good actually.  400km.
installing new gasket on the oil fill side.
« Reply #472 on: October 02, 2016, 02:04:50 AM »
this is what you get when you over fill the oil, a popped gasket got the side of motor off,   cleaned the sides of the old gasket material,  looks like it was glued on in spots,  wondering if I should use gasket in a tube , with the paper gasket from kymco, would it hold better, any ideas???  new stuff on the market I never used before,  haven't done a engine job in 50 years,.
kneeslider
« Reply #473 on: October 12, 2016, 01:32:03 AM »
Got my steering head bearings replaced & the main belt as well.
Funny enough, I preferred how it handled when it was notched at the middle (going straight). It felt much more stable.
« Reply #474 on: October 12, 2016, 07:49:41 AM »
   It takes a few days to get use to no notch,  took me about a week,.   de dee
tvniklas
  • Passed the golden age 40...
« Reply #475 on: October 17, 2016, 03:28:22 PM »
Today i replaced my DrPulley 15g with the orginal to see if it makes a difference.
I have now driven 250km with the Pulleys and today i made only a quicktest of the rollers.
Slower and more shake, but more powerful at start.
500 lower Rpm at 50mp.
More calm at cruising.
I changed mostly because when i bought the Pulleys, i clean the variator and it was really dirty with lots of thick dust so the rollers didnt get a fair chance.
I'l get back tomorrow after 50km different roads.
Have a nice evening! (17:27 in sweden)
« Last Edit: October 17, 2016, 07:18:13 PM by tvniklas »
Kymco Downtown 300i ABS -2013
ODO: 9950km
Dr Pulley 15g / Orginal rollers  (change all the time)
Gas average 0,29L/10km
Kymco Like 125  -2016  -Sold
Kymco Agility 50 -2015 -Sold
I have 14g ,15g and 15,5 Pulley´s to sell
kneeslider
« Reply #476 on: October 18, 2016, 02:50:48 AM »
What were the weight of the original rollers?
If the original rollers were 15g as well, would it mean you would get a similar result?
I am confused how the selection of weight works when the dr pulley profile allows for a higher rpm at low speed and a lower rpm for higher speeds.
Maybe perhaps its just best to use original weight with the dr pulley's profile?
tvniklas
« Reply #477 on: October 18, 2016, 10:28:13 AM »
The orginal rollers are 15.5g
DrPulley recommends 10% lower weight than orginal, so 14g according to them would be a better choise.
But after reading this thread about 15 times: http://www.kymcoforum.com/index.php?topic=4700.0
i decided for 15g, not sure if it was the best, but! for the DT300 it seems as 14, 15 or 15,5g is the way to go.
But som people warns about the Pulles that they can destroy they variator, but you decide for yourself.
P.S. I have just bought this machine, and are just in the learning face of it, theres a lot pro people in this forum that can help you better.
« Last Edit: October 18, 2016, 02:53:23 PM by tvniklas »
ODO: 9950km
TANWare
« Reply #478 on: October 18, 2016, 01:43:02 PM »
You have to think of the sliders slightly differently than rollers. There are two things affecting it;
1.) first is the weight. this creates the force closing the front variator and decreasing the ratio for the drive. The heavier the weights the faster the rollers etc. will decrease the ratio with increased RPM.
2.) second is the rollers diameter. With a larger diameter of the roller the more it will want to close the variator making it reach a lower gear ratio faster. With sliders this is a bit different. The fact is with the design the profile changes making it where at idle it looks like a small diameter roller but as the rpms increase and the slider moves out it increases the profile making it look like a larger diameter roller. This cam effect is what give them their advantage. Essentially a larger gear ration range.
« Last Edit: October 19, 2016, 12:41:28 AM by TANWare »
tvniklas
« Reply #479 on: October 18, 2016, 03:34:30 PM »
Okey, do today i took my baby to work( 45km) to test the orginal rollers, and i must say that they are dissipointing after ive tried the Pulley.
The takeoffs are more shaky and the acceleration is way better with DrP.
Its more uncertain in carcues/line at low speed.
The Pulleys are getting back in asap.
Great explanation @TANWare, thank you.
ODO: 9950km
