Author Topic: What did you do to your DownTown today?  (Read 159956 times)
tvniklas
  • Passed the golden age 40...
Re: What did you do to your DownTown today?
« Reply #630 on: September 08, 2017, 04:56:23 AM »
Thanks Karl
Then i know now that nothing serious will happen today on the way tork 😄
TV, I meant to get back on this sooner, sorry! The grease in the tube between the bearings is no big deal as long as the seales at both ends are operational. The one next to the roller bearing is the weak one but yours looks good.
Kymco Downtown 300i ABS -2013
ODO: 9950km
Dr Pulley 15g / Orginal rollers  (change all the time)
Gas average 0,29L/10km
Kymco Like 125  -2016  -Sold
Kymco Agility 50 -2015 -Sold
I have 14g ,15g and 15,5 Pulley´s to sell
« Reply #631 on: September 25, 2017, 12:36:02 AM »
Changed oil & filter at 6116 miles new, old stock DT300i.
Snorvey
« Reply #632 on: September 26, 2017, 11:01:35 AM »
My speedometer went funny this morning, reading zero for the first 10 minutes of my journey. I initially thought the cable had snapped, but then it came back to life in a fairly erratic way. So maybe not snapped, but loose?
« Reply #633 on: September 26, 2017, 12:56:07 PM »
Eletronic not cable driven.
Snorvey
« Reply #634 on: September 26, 2017, 02:55:16 PM »
Gawd almighty <groan>. What was wrong with using a normal, reliable (sort of), easy to replace cable?
After a quick glance, there is a cable roughly in the location of where a speedo should be at the front wheel. What's that then?
« Reply #635 on: September 26, 2017, 05:16:12 PM »
Inspect carefully, the do-dad at the end of the wire (cable). It has to be fairly close but not touching the tone wheel, that thingy bolted to the front wheel hub. Elevate the front wheel and give it a spin to see if the tone wheel is straight, the wheel runs true and does not slide side to side.
Snorvey
« Reply #636 on: September 26, 2017, 05:43:00 PM »
Thanks Karl.
The bike is tucked away for the night. I'll check it out tomorrow.
« Reply #637 on: September 26, 2017, 08:45:29 PM »
Well, OK! But I'm gonna hold my breath until.....
mousejunks
« Reply #638 on: September 27, 2017, 03:02:02 AM »
I wrote up a fix for that a year ago:
http://www.kymcoforum.com/index.php?topic=23607.0
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
kneeslider
« Reply #639 on: October 18, 2017, 06:11:08 AM »
Found my air intake tube was loose, so while replacing my airfilter, I got some epoxy and glued it back into place.
Sent from my HUAWEI VNS-L31 using Tapatalk
2019 Yamaha X-Max 250
kneeslider
« Reply #640 on: October 18, 2017, 06:12:46 AM »
While the epoxy was out, I dabbed it into the bolts which hold my driving lights to the bike as a theft prevention method.
« Last Edit: October 19, 2017, 05:00:03 AM by kneeslider »
kneeslider
« Reply #641 on: October 23, 2017, 06:19:14 AM »
New set of Pirelli Diablo Rosso Scooter tires fitted at 58000kms.
kneeslider
« Reply #642 on: October 24, 2017, 08:05:25 AM »
Mileage 58170km.
New drive belt installed and CVT serviced.
She's so smooth now.
pipster326
« Reply #643 on: October 24, 2017, 06:49:39 PM »
Hey Kneeslider, after you put some miles on those new pirelli’s, how about a review...
Rich
kneeslider
« Reply #644 on: October 25, 2017, 07:26:03 AM »
Sure.
But initial thoughts after covering 200kms since they got fitted:
* please note my comments are comparing them directly to the Michelin Power Pure SC fitted previously. http://moto.michelin.co.uk/GB/en/tyres/products/power-pure-sc.html
1) Turning in is slower than the PP SC, probably due to the Diablo Rosso's (DR) profile
2) DR ride is more compliant. Not as harsh as the PP SC, but that dulls the 'feel' thru the bars
3) Due to #3, at lean, it is calmer but lacks the feel. Perhaps I need more time to get used to it
4) DR is quieter
Will return to this when I get more miles on it.
Rich
