Author Topic: What did you do to your DownTown today?  (Read 160051 times)
Snorvey
Re: What did you do to your DownTown today?
« Reply #675 on: November 15, 2017, 08:19:20 PM »
Looks good. I might look into one of those.
« Reply #676 on: November 15, 2017, 10:48:57 PM »
Checked TBS. That stainless bracket is $25 usd! Might wait awhile.....
kneeslider
« Reply #677 on: November 16, 2017, 02:27:18 AM »
Have a look in eBay, there they have one that doesn't require that additional self-tapping screw.
2019 Yamaha X-Max 250
lolofigo
« Reply #678 on: November 19, 2017, 02:45:43 PM »
I have just changed the oil and filter surprisingly oil drain bolt was with little magnet. Is that standard on Downtown or previous owner improvement? Also replaced rollers with Dr pulley sliders 13.5g and sanded off clutch shoes. I've only had a chance for a short test drive to warm up the oil before changing but I'm quite happy with acceleration now. It's like it pulls away in 1st gear instead of something like it felt 2nd before.
Sent from my SM-N9005 using Tapatalk
« Reply #679 on: November 19, 2017, 09:54:49 PM »
Magnet standard.
lolofigo
« Reply #680 on: November 27, 2017, 08:57:46 PM »
I have put lock on storage compartment. It was just couple quid from eBay. Why kymco saved on this is beyond my understanding.
kneeslider
« Reply #681 on: November 28, 2017, 06:48:28 AM »
That's great, do you have a link to the ebay page for that?
lolofigo
« Reply #682 on: November 28, 2017, 05:03:47 PM »
Look at this on eBay  http://www.ebay.co.uk/itm/322886595322
I have to cut that latching bit on new lock to look like the old one with dremel.
Snorvey
« Reply #683 on: November 29, 2017, 08:59:34 AM »
Nice job. Can I ask what size you went for?
lolofigo
« Reply #684 on: November 29, 2017, 09:10:01 AM »
25 mm
Snorvey
« Reply #685 on: November 29, 2017, 09:51:42 AM »
Thanks. I've ordered one up.
kneeslider
« Reply #686 on: November 30, 2017, 12:57:49 AM »
Drats, I don't have access to a dremil.
Sent from my HUAWEI VNS-L31 using Tapatalk
kneeslider
« Reply #687 on: November 30, 2017, 01:06:02 AM »
Was doing an engine and gear fluid (with oil filter) done last week. The 'low battery' hasbeen playing up. Workshop checked tje charging output, magneto was cutting in and out. No stock available so had to get rewound.
While having that done, to get to the magneto, coolant too had to be dropped, so new coolant went in, due time too as it's the factory fill that's been with me since 2013.
And had the front forks serviced with new synthetic fork oil. And while doing that found out my wheel bearings were on their way out. So went in new ones. Mind you, this new set would be set number 3.
Damn I hate maintenance.
stuo
« Reply #688 on: February 07, 2018, 11:57:49 PM »
Thanks, lolofigo, for a great tip. The lock works perfectly.
2009 GV 250
Grumpet
« Reply #689 on: February 08, 2018, 04:25:42 PM »
i hope i am not necroposting, i really  like the idea of putting a real lock instead of a plastic  thingy.
So the "dremel" tool is to cut the metal border on the lock?
On topic I used my kymco to go to the gym and todo shopping, i hope to use it for a long trip one of these days( Cheshire-Snowdonia)
