Author Topic: What did you do to your DownTown today?  (Read 160111 times)
Re: What did you do to your DownTown today?
« Reply #690 on: February 08, 2018, 05:21:42 PM »
Grump, it always looked like the British Isles had great roads so you have no excuse!
Grumpet
« Reply #691 on: February 08, 2018, 05:50:19 PM »
if i am able get some holiday i will do it........... unless i get lost, wich is something i do really easily...Cheste-market drayton 6 hours XD
stuo
« Reply #692 on: February 08, 2018, 07:54:29 PM »
The dremel is to make the metal locking tab (the part that unscrews at the end of the lock) the same size and shape as the plastic one on the DT. I used my grinder with an 1/8" blade to do it. It isn't critical to get it exactly the same, close is OK, because mine works and it ain't a perfect match.
2009 GV 250
Snorvey
« Reply #693 on: February 10, 2018, 02:39:42 PM »
Attempting to fix my broken speedo cable. Any thoughts? It snapped flush with the connector. I've tried to dig out as much of the old electrical wire as possible, but there is still some in there. And I'm not really sure how I'm going to re-attach the wire?
So yes, any ideas most gratefully received! (pic of connector with the plastic cover slid off)
« Reply #694 on: February 10, 2018, 04:25:41 PM »
Show that pic to the salesman at RadioShack. ....he'll have a connector, maybe.
Crimp something onto the wire that inserts into the black bit, with an adhering collar?
Snorvey
« Reply #695 on: February 10, 2018, 04:51:02 PM »
It's worth a go Stig - thanks. I could pop into my local car/bike parts retailer to see if they have anything suitable I guess I then have to snip off BOTH connectors and re-connect wires using a new connectors?.
mousejunks
« Reply #696 on: February 11, 2018, 03:06:33 AM »
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
Snorvey
« Reply #697 on: February 11, 2018, 09:19:58 AM »
That's the very thing MJ. Time to get the soldering iron out. Thanks!
stuo
« Reply #698 on: February 12, 2018, 01:54:08 AM »
Hey Stig, Have you been in a time machine...or am i out of it? Radio Shack went bust years ago, didn't they?
2009 GV 250
kneeslider
« Reply #699 on: February 13, 2018, 01:34:21 AM »
Won't it be easier to just snip of the male & female connectors and replace them with new bullet ones? Make sure you electrical tape them up, zip ties on both ends and heat shrink it for water proofing.
2019 Yamaha X-Max 250
Snorvey
« Reply #700 on: February 17, 2018, 03:11:15 PM »
Alright friends? (Oh God, what does he want now...)
The speedo is fixed (I have to admit I took the Kneeslider option here - bullet connectors and then I cocooned it in insulating tape)
It's the first time I've had the top fairing off. It was relatively easy job and, more surprisingly, quite easy to put back on again.
I have a question though. There are two recessed threaded holes in the main body of the plastic either side of the coolant cover (I can take a pic if needed)
What are they for? Have I missed something? Taking off the cover and looking behind the plastic they don't seem to do much.
Most importantly, I don't seem to have any bolts left over (unless 2 have rolled off the workbench)
Any thoughts?
Snorvey
« Reply #701 on: February 17, 2018, 04:07:21 PM »
Picture!
Snorvey
« Reply #702 on: February 17, 2018, 04:51:22 PM »
As I had refitted the screen, I needed to have the flash on to see properly. You can see the two holes I mean to the left and right of the coolant cover.
Cheers!
« Reply #703 on: February 17, 2018, 06:23:46 PM »
Oh! Gotta check mine! Standby.....
« Reply #704 on: February 17, 2018, 10:00:42 PM »
They were there the last time I stopped in.
