Did you miss your
activation email
Scooters - 50cc
Super 8
Oil Switchout Process?
Topic: Oil Switchout Process? (Read 657 times)
Super8:50:2T:2013
Newbie
May 20, 2014, 10:54:42 PM »
Ok, I want to switch out the Honda GN2 for Amsoil Interceptor Full Syn. Injector oil.
My Question: After I drain the GN2 Oil, What is the bleed/prime process when I put in the Amsoil Oil?
Thank you in Advance for your responses.
You never know do ya!
Close enough to get the idea!
Re: Oil Switchout Process?
May 21, 2014, 01:03:17 AM »
I would simply pull the oil line, and let it drain out/refill. No need to bleed it.
You will see a bleeder screw on the pump. It's a small Phillips head screw. You simply pull the screw, and oil will gravity flow.
Super8:50:2T:2013
Newbie
May 21, 2014, 09:05:26 AM »
Thanks Z.
Reply #3 on:
May 21, 2014, 04:05:29 PM »
Back
