Author Topic: engine code issues  (Read 1157 times)
COFFTEA
engine code issues
« on: May 21, 2014, 08:58:46 PM »
Hi all
I have a agility 50cc KG10SA
when trying to find parts all I ever find is 139qmb
or suntimes something like bt50-qt for boation
is the KG10SA known as somthing else or is it a 139qmb in disguise
many thanks
Re: engine code issues
« Reply #1 on: May 21, 2014, 11:32:16 PM »
Almost all the qmb parts will fit. If you want OEM then Stadium Yamaha gives a discount for Kymco stuff.
MoToFaLcon
  • I Fly....
« Reply #2 on: May 22, 2014, 09:14:48 PM »
I was wondering the same thing.
WTF, i have a Ninja 650!!
« Reply #3 on: May 22, 2014, 10:53:08 PM »
The only parts that do not swap out are the Final Drive gear sets, and the Electrical components.
For that stuff you have to stick w/ the engine you have.
My 2t is a Kymco but all the parts swap for Dio except the above.
Kymco's are CLONES. It's all a Charaaaaade.
JJJoseph
  • Kymco Sento
« Reply #4 on: May 30, 2014, 04:59:34 AM »
In my Kymco Sento 50 I use Dio clutch & variator parts, and standard qmb139 engine parts for the rest.  I've used qmb139 gears on the rear end. One of the Kymco gears is an odd one, but you can swap it for a qmb139 gear.  Yes, the Kymco electrics are unique.  I've heard that if you swap the stator, you can use standard qmb139 electrics, but I haven't tried it.
