Author Topic: Reading post  (Read 2131 times)
nightriderrv
  • Ride all the time !!!!
Reading post
« on: May 23, 2014, 11:19:59 AM »
Is it just me or a set up change I can make on the forum, but when I read post the first person who started the post is say at the bottom of the page and have to read upward instead of reading from the top going down.
2007 Agility 50 4T KG10SA
52MM Hoca BBK
Big valve head
24mm Keihin
102.5 jet
UNI filter
Aftermarket exhaust
Malossi Multivar
6g Malossi rollers
Stock clutch & white Malossi contra spring
Primary transmission gear up 18/50
Re: Reading post
« Reply #1 on: May 23, 2014, 12:26:18 PM »
Are you in AUSTRALIA?!......this would explain your issue. Pretty sure on this ...Zombie....your thoughts on this puzzle? (See, the forum was set up by a guy in NORTH  America....just sayin)
wkreps
Re: Reading post
« Reply #2 on: May 23, 2014, 06:34:45 PM »
Go to the top menu and select "Profile - Account Settings"
Then below the banner ad click "Modify Profile - Look and Layout"
Scroll down and UNCHECK the box for "Show most recent posts at the top."
Wayne
08087
  • 09' Peoples 200, NJ
Re: Reading post
« Reply #3 on: May 23, 2014, 06:40:48 PM »
Geez, mine goes sideways from right to left and I'm not in China, what's up with that?
Re: Reading post
« Reply #4 on: May 23, 2014, 06:47:06 PM »
i'M JUST HERE TO LOOK AT THE PICTURES.
who left the cap lock on and who moved my cheese?
wkreps
Re: Reading post
« Reply #5 on: May 23, 2014, 07:33:45 PM »
Your glasses are on inside out. flip them around and you'll be fine.
Wayne
08087
Re: Reading post
« Reply #6 on: May 23, 2014, 08:37:26 PM »
Damn, how could I have over looked that for so long, thanks for the top!
Hairy Bob
Re: Reading post
« Reply #7 on: May 23, 2014, 10:20:25 PM »
Nah, it can't be that Stig. In the southern hemisphere, we just turn our screens upside down.
Damn the torpedoes .. full steam ahead !
Re: Reading post
« Reply #8 on: May 24, 2014, 02:08:18 AM »
I have a mirror. There's a setting for that?
wkreps
Re: Reading post
« Reply #9 on: May 24, 2014, 04:48:26 AM »
Yeah but you're not to use the mirror that makes things look BIGGER than they actually are.
Wayne
Re: Reading post
« Reply #10 on: May 24, 2014, 06:56:55 AM »
I have too. China daddy. >:(
Mscmkr
Re: Reading post
« Reply #11 on: May 25, 2014, 09:46:25 PM »
Just check to see which way the water is spinning in the toilet when you flush and you can at least figure out where you are.
Re: Reading post
« Reply #12 on: May 26, 2014, 04:56:55 AM »
The water shoots out!!!
Re: Reading post
« Reply #13 on: May 26, 2014, 04:57:16 AM »
Italy right?
nightriderrv
Re: Reading post
« Reply #14 on: May 30, 2014, 10:54:26 AM »
Thanks wkreps  I found the setting.
52MM Hoca BBK
Big valve head
24mm Keihin
102.5 jet
UNI filter
Aftermarket exhaust
Malossi Multivar
6g Malossi rollers
