Author Topic: Clutch springs You of great knowlege!!!!!  (Read 1454 times)
hgw75
« on: May 23, 2014, 07:06:34 PM »
http://www.ebay.com/itm/151306246132?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Would springs with less tension allow the clutch to open quicker/lower RPM????
Re: Clutch springs You of great knowlege!!!!!
« Reply #1 on: May 24, 2014, 02:50:35 AM »
Lowe tension = lower RPM engagement. But I wouldn't recommend that on the x500, the clutch engages too low as is and causes damage to the clutch and poor off the line performance.
« Reply #2 on: May 24, 2014, 07:31:05 AM »
Yes it will open sooner. If I may ask... Why would you want/need that?
I honestly do not think any are made that are softer than stock. You may have to heat treat them yourself.
hgw75
« Reply #3 on: May 24, 2014, 11:44:09 AM »
It is my understanding that at 4000 rpm from a start is when it engages, thought a little lower rpm would be better.
I am not for Shure, but in traffic from a start ,thinking a little less rpm to start off would be better!
« Reply #4 on: May 24, 2014, 03:10:51 PM »
You would burn the clutch out engaging lower for sure. Almost every x500 I work on already has a highly blued bell
hgw75
« Reply #5 on: May 24, 2014, 04:57:40 PM »
OK,thank you.... I sure don't a BLUE BA.., Bell.   ;D ;D
« Reply #6 on: May 25, 2014, 12:02:37 AM »
Yeah driving in traffic with the X500 sucks, no mods will help that!
Porkie
« Reply #7 on: May 27, 2014, 12:09:54 PM »
Driving in traffic with my 500 is Nirvana, with no clutch, excellent ABS brakes, a smooth engine that has tons of power, torque and acceleration. What could suck about that?
Leave the thing alone and enjoy. If you want something faster that is available in the US, get a T-max 500 or a Burgman 650. I've had 2 Cheeseburger 650's and a 2009 T-max 500 plus a lot of others and the Kymco 500 still puts a smile on my face because of it's effortless abilities and huge mid-range torque.
I can understand some of these folks on the little 'string trimmer' scooter's wanting some more get up and go:)
Sam:)
2014 Polaris Ranger 800 crew cab 4x4
2012 Honda Goldwing Blue
2013 Kymco Xciting RI ABS in gold/ orange
2005 Suzuki Burgman 650 blue metallic
KF6GUW Amateur Extra
