Author Topic: need help quick  (Read 841 times)
boo
need help quick
« on: May 27, 2014, 03:55:25 PM »
Having trouble removing variator nut.
Want to make sure before I go further.
"Right hand thread"?
Counter clockwise to loosen?.
So far I have used a 1/2" ratchet, power bar, electric impact wrench, and a couple of hits with a compressor and impact.
Last year the shop where I bought the scoot replaced an oil seal behind the variator. Who ever put the nut on must have used a four foot cheater bar.
Want to make sure before I try again.
Also, cannot spread clutch pulley with my fingers. Feels solid as a rock. Does the bell have to be removed before the pulley will spread open?.
thanks boo
« Last Edit: May 27, 2014, 04:07:40 PM by boo »
300GTI black
Pro 2A - member GOA & NRA
Re: need help quick
« Reply #1 on: May 27, 2014, 06:26:10 PM »
He's taking off the variator nut of this 300i....has the locking tool holding it w/wood so he can spin it counter-clockwise.
When I get a big axle nut or somesuch stuck like that... I coat it in WD40 and let sit overnight...try again in the morning.
Good luck
German youtube
« Last Edit: May 27, 2014, 06:27:52 PM by Stig »
boo
thanks Stig
« Reply #2 on: May 27, 2014, 09:31:06 PM »
That variator nut busted my chops.
Will try again another day.
Replaced the studs on my variator holding with hardened steel ones.
When I try again, I`ll use a long cheater bar and have a new nut on hand in case I have to cut the old one off.
Thanks for everything.
300GTI black
