Author Topic: 2010 Super 8 won't start  (Read 947 times)
clromig
« on: May 27, 2014, 05:28:00 PM »
Just bought a 2010 Super 8.  It ran when I first got it now I can't get it to start.  Electric start won't work, neither will kick start. Put a new gel battery in and electric start still won't work.  Shorted across the starter relay and scooter started after cranking a little.  Scooter floods out after using the kick start 3 or 4 times.  Any ideas, bad CDI, starter, starter relay, auto-bypass...not sure what to do.  Thanks
tortoise
Re: 2010 Super 8 won't start
« Reply #1 on: May 27, 2014, 06:22:58 PM »
Is the emergency off switch on the right grip in the run position?
clromig
« Reply #2 on: May 27, 2014, 06:27:46 PM »
Yes.  I switched it off and on a couple of times just to make sure it wasn't a contact issue.
2wheelfun
« Reply #3 on: May 27, 2014, 08:15:23 PM »
From your reply and ... you f***ed up your own bike.
Chris0381
« Reply #4 on: May 27, 2014, 08:26:01 PM »
I dont understand that, was there a post in this thread that was deleted ?
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
