Author Topic: Agility RS 50 cuts out after 5 seconds - runs fine when warm?  (Read 2751 times)
Stellagod
Hi, can anyone help? I've got an 09 Agility RS 50, it starts ok then cuts out after 5 seconds. I restart the scooter (takes a bit) then does the same over and over. When I manage to get the engine warm it runs fine - just takes 10 to 15 minutes!?! If anyone could give me a pointer please
Re: Agility RS 50 cuts out after 5 seconds - runs fine when warm?
« Reply #1 on: May 28, 2014, 03:12:09 AM »
Clean or new carb.or just make sure the carb is air tight .
« Reply #2 on: May 28, 2014, 09:05:59 AM »
Also time to resit the valves.
Stellagod
« Reply #3 on: May 28, 2014, 07:14:02 PM »
Thanks Blue, I've ordered a new carb - fingers crossed
JJJoseph
  • Kymco Sento
« Reply #4 on: May 30, 2014, 04:24:02 AM »
Don't forget to use new O-rings under the manifold!  The cheap Chinese O-rings go flat from the heat, and leak air. Then it won't idle.  Buy extra O-rings because they don't last long. Buy Viton O-rings for longer life
« Reply #5 on: May 30, 2014, 05:43:05 AM »
Could also be the Stator/CDI. See how the carb goes. I'd change out the fuel filter, and clean the tank screen while I was at it.
MN_Scoot
« Reply #6 on: June 02, 2014, 01:06:46 AM »
Hey JJJoseph, curious what you mean about "under the manifold?"
Also, do you know of a supplier that has the right size rings for our bikes? The parts department for the dealer I go to even had a hard time tracking down the correct o-rings for a carb rebuild.
2007 Kymco Agility 50
Stock other than Dr. Pulley Sliders and derestricted from the dealer.
« Reply #7 on: June 02, 2014, 04:48:48 AM »
There is a Bake o lite spacer under the manifold that is prone to cracking/warping. It has an O ring on each side.
I use these to replace the plastic junk... http://www.racingplanetusa.com/intake-manifold-spacer-naraku-flow-aluminum-milled-139qmbqma-p-5390-1.html?cPath=2_122_584&sessID=e1cbf98ac9a7fcd1d22ad7b4895f9193#.U4wBjlPLfAA
The O rings can be found a Ace Hardware or home depot. Just bring one, and match it up.
Stellagod
« Reply #8 on: June 02, 2014, 04:31:17 PM »
Hi, tried a new carb with new O rings and it's no different. Ordered a new CDI- we'll see how this goes. Loosing the will to live! :(
« Reply #9 on: June 04, 2014, 03:10:24 AM »
Sorry to hear that but on the bright side you are starting a good parts bin. You're gonna need it.
Did you check for spark when it WOULDN"T start?
Stellagod
« Reply #10 on: June 04, 2014, 06:54:51 PM »
Parts bin has been expanded by a CDI which has made no difference!! Does anyone want a burnt out Agility RS 50??  :'(
« Reply #11 on: June 04, 2014, 08:11:57 PM »
Is there spark when it WON'T start?
Stellagod
« Reply #12 on: June 05, 2014, 09:21:51 PM »
Hey Zombie. Yes it's got a good spark when it's cranking over before it fires. All I can say is the new carb has improved the time it takes to restart and it now runs for about 10 to 15 seconds before it dies. And again, when it's warm it runs fine?!?
« Reply #13 on: June 05, 2014, 10:05:49 PM »
Have you checked for voltage on the auto choke. I hate to say it but we all may have overlooked that.
There is supposed to be +12 volts when the key is turned on. I think they are green (Gnd), and yellow (+12v).
tortoise
« Reply #14 on: June 05, 2014, 10:36:09 PM »
2-stroke or 4-stroke engine?
