Author Topic: cutting out in reverse  (Read 990 times)
bism45
« on: May 27, 2014, 08:14:47 PM »
my mxu 250 cuts out when i put it into reverse and give it throttle but everything else is fine ?? can any one help please ??
souzamoto
Re: cutting out in reverse
« Reply #1 on: June 09, 2014, 08:29:47 PM »
Does your 250 have a yellow button on the right handlebar switch cluster? If so, hit the button while in reverse and you will have full RPM power in rev.
It cuts out in Rev due to the rev limiter built in. Safety feature
bism45
« Reply #2 on: June 21, 2014, 08:19:02 PM »
thanks but no...no switch and i have four more of the same quad and none of the others have this problem ?
