Author Topic: Nice Ride today and bike is nicely responsive.  (Read 1884 times)
Chris0381
« on: May 27, 2014, 08:23:59 PM »
Took a ride making sure to treat my one key left like a raw egg.
85 degrees, breezy, and slightly humid; quite cool in mesh padded jacket and helmet visor slightly parted. Have 400 miles on the odometer now. Was getting 37 MPH on the flats. Cycle seems to be quite responsive.
So far just the smooth boss and 82 jet. Can only imagine what a slight mod of some sort may bring for MPH. I hope this performance improves as I break in the engine.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
Chris0381
Re: Nice Ride today and bike is nicely responsive.
« Reply #1 on: May 29, 2014, 08:49:16 PM »
Today was 65 and cool and dry. The scooter seemed to have trouble getting past 35 MPH on the flats. Wondering if hat humid weather is more ideal for performance.
Smooth Boss
Polini Variator
#95 Main Jet
« Reply #2 on: May 29, 2014, 10:35:27 PM »
You may just be on the verge of running lean. Try to enrich the Idle Mix screw 1/2 turn or so. You might also want to check for the correct spark plug BR8HSA I think it is.  I have been running BR9HSA's for quite some time, and being a colder plug they tolerate leaner mixtures better.
Only problem is you have to order them from Poland or Japan. They are not sold in the US.
http://www.ngksparkplugs.com/tech_support/spark_plugs/p2.asp?mode=nml
« Last Edit: May 29, 2014, 10:39:01 PM by zombie »
Chris0381
« Reply #3 on: May 29, 2014, 10:43:52 PM »
TY Zombie
My idle screw is sealed but wondering if I should give upjetting form #82 a tray maybe 90 or 92 ?
Smooth Boss
Polini Variator
#95 Main Jet
« Reply #4 on: May 30, 2014, 03:34:28 AM »
I would say 84-86 maybe 88. You can drill out the cap on the Idle Mix screw as well. That would have been the very first thing done.
Chris0381
« Reply #5 on: May 30, 2014, 11:07:30 AM »
I'd like to do that but could use a youtube walkthru. Read a post or 2 about people ruining their carbs trying to expose the idle screw.
Smooth Boss
Polini Variator
#95 Main Jet
245luigi
  • Boston, MA
« Reply #6 on: May 30, 2014, 12:59:43 PM »
Remove the carb. Using an exacto knife try to detach as much adhesive around the cap as possible. Try to spin the cap (There is adhesive underneath it too) then use compressed air to blow it out of the housing.
Thats how I did it. Not very professional/technical but I didnt have to use a drill. You will need a D slotted adapter for the mixture screw http://www.amazon.com/gp/product/B003CMWC4U/ref=oh_details_o06_s00_i00?ie=UTF8&psc=1
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
« Reply #7 on: May 30, 2014, 03:47:18 PM »
You don't need the special screwdriver, just dremel a flathead slot in it with the cap off. I've seen fuel screws out 5 1/2 turns factory set!!! Ran horrible.
« Reply #8 on: May 30, 2014, 07:04:01 PM »
« Last Edit: May 30, 2014, 07:08:48 PM by zombie »
Chris0381
« Reply #9 on: May 30, 2014, 10:39:34 PM »
TY for the video. I'd use a very tiny bit and just force the hole open with a Stainless Steel screw. After all its only brass.
That shouldnt be too bad.
Smooth Boss
Polini Variator
#95 Main Jet
« Reply #10 on: May 30, 2014, 11:06:53 PM »
Worst case is the collar stays in the bore, and you simply open the end.  ;)
herrspoot
« Reply #11 on: September 26, 2014, 12:34:51 AM »
Does this adapter work on the stock 16mm Keihin carb or is this one for your 19mm that you put on your bike?
2012 Like 50 2t
  Derestricted bushing
  Derestricted stock exhaust
  Derestricted stock airbox
  100 MJ
  Biondi windshield (with custom mounts)
"The pen is mightier than the sword, and is considerably easier to write with." Marty Feldman
« Reply #12 on: September 26, 2014, 12:47:23 AM »
The adapter is the same one for all bikes. You can even use a serrated steak knife to cut a slot if needed.
Start at 2 turns out from seated for your base line. Like B&L stated earlier the factory settings are all over the place, and more often than not... wrong!
herrspoot
« Reply #13 on: September 26, 2014, 01:37:05 PM »
   Thanks!
2012 Like 50 2t
  100 MJ
