The hardest part about doing LEDS in the super 8 is opening the damn thing up, prolly the hardest 150 Kymco to get into. You will need to drill holes for 1156 base sockets into the trail light housing, then epoxy the sockets in. Not to hard and most of the work is figuring out how to remove the tail plastic. Like zombie said, if you do use leds you will need to use a led flasher or install inline resistors.
