Did you miss your
activation email
Scooters - 50cc
Front end Wobbles
Topic: Front end Wobbles (Read 934 times)
Rico625
Newbie
Front end Wobbles
May 28, 2014, 11:53:21 PM »
Hi When I ride my scooter and coast to a stop light and then let go of the handle bars the handle bars wobble bad and they never used to do that and I have not crashed or had any front wheel damage
and Ideas?? maybe the Steering stem lock nut
Thanks
DMblues01
2012 Kymco Super 8 150
Sr. Member
Re: Front end Wobbles
May 29, 2014, 03:16:57 AM »
Check for any loose bolts or nuts in the handle bars and front end.
Roxana, IL
Yoda is my spiritual leader.
You never know do ya!
Close enough to get the idea!
May 29, 2014, 03:42:25 AM »
Loose nut behind the wheel.
You knew...
woodcutter
Full Member
Reply #3 on:
May 29, 2014, 08:27:00 PM »
- front wheel out of alignment
- worn wheel bearings
- worn or loose steering bearings
just my first thoughts
Reply #4 on:
May 29, 2014, 10:12:41 PM »
Lock up the front brake, and try to rock the bike in any direction. That may help locate the loose part(s)
The moped learner
Full Member
Front end Wobbles
Reply #5 on:
June 03, 2014, 01:16:15 AM »
Or the tire pressure could be low i deflated my front tire to go off roading and it acted as is the bike had a mind of its own
Reply #6 on:
June 07, 2014, 02:21:01 AM »
The trible tree might need adjusted.
Back
