Did you miss your
activation email
Scooters - 50cc
Super 9
Low compresion Super9s
Topic: Low compresion Super9s (Read 1512 times)
yogi
Newbie
September 21, 2009, 06:48:36 PM »
Hi guys just wondering what the compression should be on the Aircooled super 9, Ive carried out a compresion test and it's only reading about 80 psi at WOT spun over about 10 times......Any help appreciated
OldGuy
Full Member
Re: Low compresion Super9s
September 21, 2009, 11:44:12 PM »
To take an accurate compression test the motor needs to be fully warm and the throttle fully open. Cold and/or the throttle closed will cause low readings.
OldGuy
Wanna be GrandVista rider
"What the heck happened?"
You never know do ya!
Close enough to get the idea!
September 23, 2009, 12:06:38 AM »
Should be right at 100. You may want to put in a set of rings. You can take the glaze off the cylinder w/ 600 grit emory paper, and a good oil. ONLY CUT in a circular motion around the inside. Never from top to bottom
yogi
Newbie
Reply #3 on:
September 23, 2009, 06:06:10 PM »
Thanks for the replys guys, i'll check it again tomorow when it's warm .
Back
