Author Topic: Kymco People S - connector for alarm system ?  (Read 861 times)
zero
« on: May 29, 2014, 11:51:54 AM »
Anyone know is there original connector for easy mounting alarm system ?
Re: Kymco People S - connector for alarm system ?
« Reply #1 on: May 31, 2014, 03:28:25 AM »
No. It's not like the cheap China bikes that are pre wired.
The easiest thing to do is add a motion sensor/DPDT switch.
Wire the switch to power the motion sensor which in turn will fire the horn on one side, and use the other side as an Ignition interrupt. A latching relay can be used to lock the horn on until you deactivate it but it's usually not needed to scare someone off. the whole deal costs less than a pack or two of smokes.
I can draw up an easy schematic for the wiring if you need one plus a parts list.
zero
« Reply #2 on: June 01, 2014, 04:44:48 AM »
Thanks my friend. I can do it  with cables and installation :) But I'll be happy to see and your scheme and part list.
p.p.   By the way, I changed the variator, now the bike runs great! I'm very happy. I changed and 3 small clutch springs with +15%
