Author Topic: Where do the parking light wires go ?  (Read 1072 times)
Chris0381
« on: May 29, 2014, 08:53:50 PM »
On USA models where the fronT parking lights dont work but are there bulb and all, where do the wire ends go? Are they hanging loose, do they have connectors on them or are the hidden in the wire harness.
TY
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
Re: Where do the parking light wires go ?
« Reply #1 on: May 29, 2014, 10:28:41 PM »
They are actually Blinker lights that are wired in for Euro/Asain bikes. Follow the ends of the blinker stalks, and the wires to the cowl lights are wrapped into the harness. You simply unplug one to the other.
Chris0381
« Reply #2 on: May 29, 2014, 10:46:39 PM »
TY
Wouldn't hurt to remove the front plastic and explore. Thinking of using the sockets and  lights  in the empty light spaces left and right off the headlight.
Smooth Boss
Polini Variator
#95 Main Jet
« Reply #3 on: May 30, 2014, 03:32:19 AM »
You can add them into the rear marker light or license plate light but I HIGHLY recommend using all LED's in that circuit. The stator cannot handle any more power than the bike draws stock.
Chris0381
« Reply #4 on: May 30, 2014, 11:08:18 AM »
Yep Im looking into LED's now. TY Zombie. Any idea what the max amperage output for the alternator is or the cutoff where it doesnt or fails charge the battery anymore.
Smooth Boss
Polini Variator
#95 Main Jet
« Reply #5 on: May 30, 2014, 07:29:38 PM »
35 amps continuous, 50 peak (time it takes to charge a flasher.)
Also get the electronic flasher relays made for LEDS   http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313.TR0.TRC0.H0.XLED+flasher+relay&_nkw=LED+flasher+relay&_sacat=0&_from=R40
Without that the LEDS wont trigger
Chris0381
« Reply #6 on: May 30, 2014, 10:40:10 PM »
TY
More great info!!
Smooth Boss
Polini Variator
#95 Main Jet
