Author Topic: Fuse blows every time I attempt to kick start  (Read 832 times)
Nickmcstein988
« on: May 31, 2014, 09:52:41 AM »
Just bought a new Cdi unit, and fitted it and tried starting still nothing, tried kick starting still nothing. Then checked the fuses and one was broke so I fitted a new one and tried to kick start again, but every time I trie to kick start it the fuse blows and when I put a new fuse in and trie electric starting, it won't start,
Any ideas?
Re: Fuse blows every time I attempt to kick start
« Reply #1 on: May 31, 2014, 05:10:39 PM »
It sounds like a short in the wiring. Why exactly did you buy a new CDI? No Start?
Check the ground that attaches to the engine first.Then try unplugging all the harnesses one at a time untill you stop blowing fuses. From there you should be able to find where the short is. My first guess is the Light Controller behind the front cowl.
« Reply #2 on: June 01, 2014, 03:02:47 AM »
X 2 bad ground. Or you got the wrong cdi.
ConradFr
« Reply #3 on: September 13, 2014, 05:54:38 PM »
Hi
Exactly your CDI can perhaps fit for your Kymco but be sure that
Its a DC CDI and not an AC CDI
Ask to the dealer for the pin connections so you can wire it correctly
Bye
