Author Topic: Kymco Super 8 2t Parts selection  (Read 782 times)
Gatorballs
« on: June 02, 2014, 04:24:18 AM »
So I'm trying to get my parts list for my 1st round of upgrades for my stock but derestricted scooter.
  Here is what I have so far.
1. Pipe - going with the Tecnigas Triops
2.Variator -
   1st choice is Jasil SV1 (Does not come with Torque spring. Do I need to buy one   and if so which one would be a good choice).
   2nd choice Jasil Next Generation (It comes with torque spring).  It is about 26 dollars more than the SV1 but with matching spring, maybe worth it.  Also not sure if it is better and why than the SV1.)
3.  Clutch -
   1st Choice - Stage6 MKII (I assume that it does not come with Clutch bell.  Do I need a new one now or can I upgrade later and use stock one for now.  If so they have a Wing Cooler version and the R/T Clutch Bell that comes in 3 different sizes 460, 480 and 500.  Which would be good?)  Most of the places are out of stock for this clutch, so may have to go with 2nd choice
   2nd Choice -  Malossi Delta
Will I need a different contra spring with any of these.  If so which one?
4.  Roller weights -
Trying to decide on which ones to start with.  Stock is 8.5 I believe.  Thinking of 6.0 grams to start with and probably lower later if it needs it.
What do you think about these for starters?
Thanks
Greg
70 kit and carb, etc to come later.
