Author Topic: Where to find???  (Read 649 times)
Bob Ryder
Where to find???
« on: June 05, 2014, 08:20:12 PM »
Custom rims/wheels?
I have the 2012 super 8 2t with the 14 inch wheels.  Tires are slim pickings in stock size for rear tire so I was wanting to go a little wider which gives more options.    Stock is 120 in width, 140 is easier foun.  With that much difference I figure the rim should be up scaled as well.  Or is shiming the rim safe?
I'm also looking to personalize her a bit.
Re: Where to find???
« Reply #1 on: June 05, 2014, 10:49:27 PM »
http://japan.webike.net
These guys are GREAT! I had found a few others in Taiwan but I forget the sites.
If you use Surf Canyon, and learn How to use it... You will be amazed at what you can find. (it's a counter intuitive search engine that works better than Google) Key words there are" Counter intuitive."
« Reply #2 on: June 06, 2014, 02:15:00 AM »
I haven't personally tried the 140 rear but look at the gap between the shock and tire if there is a little space you should be able to squeeze that tire on. No need to go with larger wheels.
« Reply #3 on: June 06, 2014, 03:23:33 AM »
New wheels are just too sexy to not have them. It's the only thing I have not changed on my bike. Literally.
