Author Topic: HELP! Bike won't start, need advice  (Read 8784 times)
24auhr
Re: HELP! Bike won't start, need advice
« Reply #15 on: June 24, 2014, 05:56:27 AM »
Hi everyone , i have a lot of time on my hands at the moment so iv been scouring the net looking for possible answers to my problem
i found this image , do you think this may be the problem ?
even if its a hint or a part of the problem , its good to have a lead
http://kymcopartsonline.com/catalog/diagrams/201205290958170.Xciting%2050_Emblem_Stripe.jpg
« Reply #16 on: June 24, 2014, 06:17:44 AM »
Those stickers aren't gonna fix themselves
« Reply #17 on: June 24, 2014, 07:33:48 PM »
start over. Details!!!
24auhr
« Reply #18 on: June 24, 2014, 09:49:36 PM »
lol bettingandlosing
my point is ,,,,, every time i fill up i fill all the way up to the cap , so mabey iv damadged the evaporative emission control system , you see now ?
on the sticker it states that if you do that it will promote hard starting and engine hesitation
« Reply #19 on: June 24, 2014, 10:03:04 PM »
Ya fixed it. YAYYYYY!
I think this is really more for Blue.
24auhr
« Reply #20 on: June 24, 2014, 11:00:08 PM »
yeah , good one zombie
« Reply #21 on: June 24, 2014, 11:40:25 PM »
It would be an hour well spent deleting the emissions system. Not that hard to do and will eliminate all possibility that is the problem.
24auhr
« Reply #22 on: June 25, 2014, 07:34:52 AM »
thanks for the advice bettingandlosing , when you say "delete" do you mean remove ?
« Reply #23 on: June 25, 2014, 03:46:33 PM »
Yeah rip all that junk out, block off any vacuum lines that were for the emissions system. It cleans up your engine bay too, less random lines everywhere.
« Reply #24 on: June 25, 2014, 04:55:40 PM »
If you live in an emissions testing state ( ie:Ct.) you can turn the idle mix screw in to induce a lean running condition. That will get you past emissions. Then simply turn it back up to normal running.
For the tree huggers... It's just a scooter not a soccer mom SUV.
« Reply #25 on: June 26, 2014, 02:02:50 AM »
I didn't even know any states test bikes/scooters. That's pretty lame.
« Reply #26 on: June 26, 2014, 04:41:57 AM »
NY does cars I'm not sure about bikes. I posted CT but I forget. It's been awhile.
LidoCA
  • I LIKE chinese plastic.
« Reply #27 on: June 26, 2014, 01:22:57 PM »
It sounds like 24 is getting closer, but what happened to the OP, HOHO?
Steve
2013 LIKE 200i LX.
2016 Yamaha SMax
2014 Yamaha Majesty
La Mirada, Ca.
« Reply #28 on: June 26, 2014, 04:17:26 PM »
HOHO is tangled up in wires on the garage floor. Something about Damn Bike...
24auhr
« Reply #29 on: July 02, 2014, 11:35:52 PM »
Just a couple of quick questions , ,
if it dosnt start after spraying starter spray into the air intake , then its not a fuel issue , is that right ?
if the problem was an earth leak , wouldnt the battery be flat very fast after a period of no positive charge ?
