Sounds like a lean condition still. Try checking as shaka suggested, and check for air leaks ie. reed gasket, cyl base gasket, carb mount, case seals... I saw a post on utube where the fella used a rubber bulb (like a blood preasure thingy) removed and plugged the exhaust port, removed the carb, and preasureized the entire engine to 6lbs. Great idea for finding bad seals. Ps... I hope you took the carb completely apart before dipping as the dip will DESTROY all the rubber parts. Pss. silicone based gasket sealers will not work around fuel. (just an after thought)
