Author Topic: Mooped won't start  (Read 680 times)
Nickmcstein988
Mooped won't start
« on: June 07, 2014, 12:04:55 PM »
My moped will not electric start or kick star. Every time I attempt to electric start it, there is either a clicking sound near the starter relay. Or it sounds likes it cranking over but won't start. It won't start when I try to kick start it either. Any ideas?
The moped learner
Mooped won't start
« Reply #1 on: June 07, 2014, 10:49:58 PM »
It's your valves its easy to adjust them
Re: Mooped won't start
« Reply #2 on: June 08, 2014, 02:26:51 AM »
Check for spark / fuel in the carb / compression test. They all have to be present for the engine to run.
the clicking is the starter relay. You can replaec the OEM relay with a Bosch, and a few new connectors. Post up if you need help with the wiring.
http://www.amazon.com/RELAY-BOSCH-30AMP-SPDT-12V/dp/B001JT016Y
