Author Topic: Would like higher mirrors.  (Read 3056 times)
Chris0381
« on: June 10, 2014, 11:04:47 AM »
I would like my mirrors on my 2013 2T to be higher so I dont have to put my head down to look at them. Are there any aftermarket mirrors that someone would recommend that are a bit taller ?
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
Re: Would like higher mirrors.
« Reply #1 on: June 10, 2014, 05:15:35 PM »
Search long neck Italian scooter mirros on eBay. Not cheap for a pair....but I sure like how much I can see behind me.
Chris0381
« Reply #2 on: June 11, 2014, 11:34:37 AM »
TY Stig will look them up.
Smooth Boss
Polini Variator
#95 Main Jet
blackhawkfan
« Reply #3 on: June 13, 2014, 12:49:53 AM »
Check out cnc mirror riser extenders on amazon.  I haven't tried them yet but they look like they might help you out.
Proud owner of a red 2013 Kymco Super 8 150k
Scooter is stock
Chris0381
« Reply #4 on: June 13, 2014, 11:16:12 AM »
Thanks BlackHawk, do you know off hand if the mirror is 8 or 10 mm. Can check that this weekend though. I like the thought of rising and extending.
Smooth Boss
Polini Variator
#95 Main Jet
blackhawkfan
« Reply #5 on: June 13, 2014, 11:52:01 AM »
I had written to Kymco about that--they said 8mm but did not sound entirely sure. I've copied their e-mail below--just doesn't seem as certain as they should be.  I would measure first.  As I am also thinking about getting these, I'm hoping to check this weekend.  I am also planning to write to the seller to find out about the threading issue.  Per wkrebs helpful videos (find his stuff on the super 8 150 forum) both mirrors have to be unscrewed in a counterclockwise direction.  I don't know if that is what they refer to as standard threading, though.
From: Drazan Jerkovic [mailto:djerkovic@kymcousa.com]
Sent: Wednesday, May 14, 2014 2:59 PM
 To: 'Getinfo'
 Subject: RE: mirrors
  It should be 8mm
    Drazan Jerkovic
 Warehouse Manager
       Kymco USA
  www.kymcousa.com
Scooter is stock
blackhawkfan
« Reply #6 on: June 13, 2014, 12:23:36 PM »
Do a search for mirror extenders in the super 8 150 forum, someone else ordered them and puts a link to the ones he got.
Scooter is stock
« Reply #7 on: June 13, 2014, 12:30:30 PM »
Got a set of those extenders....I forget now why they have been in the bottom of my tool box for a year. The long neck Italian mirrors ("moto-science" ebay seller) worked better for me...paid @$5 for the adapters. All of it from eBay.
blackhawkfan
« Reply #8 on: June 25, 2014, 11:48:38 PM »
Got the extenders and installed them on my S8 tonight.  They seem to be nice quality.  I tested the fit by screwing the parts togeter by hand to make sure everything worked right.  You have to remove the windshield before you can remove the mirrors; watch #2 of wkrebs excellent videos on youtube about removing panels from the S8 on how to do it.  I did not take the scoot for a test run with them yet, probably will tomorrow.  You'll have to sit on the scoot and work with your wrenches while adjusting them so you can tighten them into the proper position. If they work as I hope they will they will be an excellent investment for my scoot.
Scooter is stock
« Reply #9 on: June 26, 2014, 01:27:40 AM »
I recommend making them just snug enough to stay while driving. Reason is if the bike falls you want them to spin out of harms way rather than snap off.
« Reply #10 on: June 26, 2014, 02:18:37 AM »
Bar end mirrors work good and look sweet too.
Chris0381
« Reply #11 on: June 26, 2014, 11:40:41 AM »
Could you post a link to your source. Glad it worked well for you. Will also look into bar end mirrors as they do look nice Bettin.
Thanks for all the input.
« Last Edit: June 26, 2014, 11:42:51 AM by Chris0381 »
Smooth Boss
Polini Variator
#95 Main Jet
blackhawkfan
« Reply #12 on: June 26, 2014, 11:48:41 AM »
http://www.amazon.com/gp/product/B00K0BOG6S/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
Z10 Motorcycle black mirrors Riser Extension Brackets Adapter 1 pair 8mm
by Z10 on Amazon'
I'll let you know how they work out once I take them for a spin, probably tonight.
Thanks for the advice about how tight they should be, Zombie
Scooter is stock
Chris0381
« Reply #13 on: June 26, 2014, 12:05:59 PM »
OK looking forward to an impartial review Blackhawk.
Smooth Boss
Polini Variator
#95 Main Jet
« Reply #14 on: June 26, 2014, 04:25:47 PM »
I doubled up on my mirrors. I have both fully adjustable in the OEM spots, and the bar end set.
The bar ends have saved my "blind spot" more than once. I paid 3.99 shipped from China for the bar ends..
