Author Topic: Best spring and slider weights for stock Agility 50  (Read 3001 times)
MN_Scoot
« on: June 10, 2014, 06:27:30 PM »
I keep reading forum posts about slider weights and can't seem to find consensus on what might be best for a stock Agility 50. 5.5g keeps coming up as a great weight for rollers, but I read that sliders are not a direct conversion.
So…I'm wondering what the best combo is for a stock Agility 50 to keep the top end about the same, but accelerate better and go up hills faster than my current 15mph.  :-\
The best guess I have after pouring through a lot of different views is a 1500 spring and 7 gram Dr. Pulley sliders.
-I am about 190lbs if that matters, but I'd like it to be a good combo for various riders/passengers.
On a separate note, I keep seeing complete kits for transmission upgrades like this:  http://www.monsterscooterparts.com/super-transmission-kit-50cc-gy6-qmb139-engines-ncy.html
-would this be overkill? Seems like a lot of people get the performance they want after only a spring and sliders.
Thanks.
2007 Kymco Agility 50
Stock other than Dr. Pulley Sliders and derestricted from the dealer.
Re: Best spring and slider weights for stock Agility 50
« Reply #1 on: June 10, 2014, 10:25:48 PM »
With the scoot being stock 5.5 rollers will work great.and a 82 jet will be great for ya.
« Reply #2 on: June 11, 2014, 02:02:36 AM »
5.5 rollers or Ninja Sliders OR 7 gr Dr. Pulley Sliders.
I like the Malossi RED spring for the rear (equal to a 2000)
Those CVT kits are generally trash. I would get either a Jasil (top Racing) or a Polini Variator, and a Malossi Delta clutch.
Reality is you don't really need those CVT parts unless you go to a Big Bore kit, pipe, carb.
The roller/slider/spring swap will get you 40-45, and great up hill by them selves.
MN_Scoot
« Reply #3 on: June 12, 2014, 12:12:47 AM »
Great, thanks.
It seems all the scoot websites I check out have higher prices than people talk about here. Are most people getting these types of parts on ebay? Or is there another recommended site?
« Reply #4 on: June 12, 2014, 12:15:58 AM »
Thought you'd never ask... Call SPI  http://www.kymcoforum.com/index.php?topic=11581.0
He'll hook you up.
Smithg27
« Reply #5 on: July 01, 2014, 11:25:55 PM »
I had the same questions when i was finding rollers/sliders. I ended up getting 5.5 dr. pulley sliders. They work great on my scoot. I take off great and can get up to about 39-41 mph and then the acceleration slows a little. It takes a bit longer but I am able to top out at around 48 on flat ground. Keep in mind these are odometer readings not correct gps speeds. Anyways if i were to buy another set of sliders I think i'd go with 6gr sliders.
I have not mixed this with different contra springs, just stock springs. Blue and Zombie i believe have more experience with mixing them. Just figured i would give a little input if you plan on getting just rollers/sliders.
« Reply #6 on: July 06, 2014, 06:26:05 AM »
Every bit of input is valuable around here. The more info we have the better the forum gets.
Thanks for helping out Smithg.
I have 7gr Dr. Pulley sliders in mine on a 100cc kit. I also think 6 gram would work out a bit better but they never wear out. I have more than 2 years on mine right now. Rollers last just a few months for me.
