Author Topic: Break in period for new Super 8  (Read 1492 times)
Ms. Rev Limiter
« on: June 11, 2014, 04:21:58 PM »
How many miles are required before performance improves? I'm right at 60 miles now and everything seems a little tight.
Thanks in advance for your feedback!
DMblues01
  • 2012 Kymco Super 8 150
Re: Break in period for new Super 8
« Reply #1 on: June 11, 2014, 06:02:19 PM »
the owner's manual give a rough break-down on break in period.
Personally, I think the first 1000 miles is all part of break in. I changed the oil and gear lube every 200 miles during that period, and then switched to synthetic oil at 1200 miles.
I'm at 1500 miles now, and she runs like a champ!
Just remember, It's a Super 8 150!  It's NOT a highway cruiser!!
If you're wanting to cruise at 60+ mph on the highway, you have the wrong scooter!
Between 35-50 mph is where this scoot's comfort zone is. It will go a little more than that, but it will beg for mercy relatively quick!
But, I'm 230 lbs, so mine has to work a little harder. If you are significantly lighter than me, you may get a little more out of it.
 8)
Roxana, IL
Yoda is my spiritual leader.
Ms. Rev Limiter
« Reply #2 on: June 11, 2014, 08:10:39 PM »
Appreciate the information! I'll switch to synthetic around 1200 mi. as well  ;D
« Last Edit: June 11, 2014, 08:36:16 PM by Ms. Rev Limiter »
wkreps
« Reply #3 on: June 12, 2014, 08:00:55 PM »
What brand/weight you using.
BTW we are neck and neck on miles. Mines just shy of 1300 too.
Wayne
DMblues01
« Reply #4 on: June 12, 2014, 08:31:40 PM »
I switched to Rotella full synthetic 5w-40. Been running smooth and happy since the change. Starts a lot easier on cool mornings too.
And the Rotella synthetic is cheaper than the Valvoline motorcycle oil I was using during break in. (Plus, I work at a Walmart, so I can buy it for 10% off)   ;D
And it's actually rated for use in all combustion engines. Diesel, gasoline, and even motorcycle engines!
Roxana, IL
