I solved my last stalling problem when I realized the carb had loosened from the intake. Tightened it up again and it ran great for about a week.
Now, I have the same symptoms, even though the clamp is now tight. Everything runs great for about the first 3-4 miles. Then, I can feel it start to lose power and if I approach a stop light, it dies as I'm slowing down. I can always get it started again by holding the throttle open all the way like you would for a flooded engine. Could the engine be flooding itself as I drive?
It often seems to happen on straight-aways with full throttle (after the first 3-4 miles). Not sure if this is a red herring, but it also doesn't seem to happen at night when it's slightly cooler.
I somewhat suspect the choke needs to be replaced since the problem is somewhat sporadic. -it also won't start in the morning without me holding the throttle open a bit for the first 2 minutes before it will idle on its own.
This problem developed after the following maintenance completed a month ago:
cleaned carb/jets (added new gasket and o rings)
adjusted valves
new fuel filter
new air filter
new spark plug
adjusted idle to rpm spec in manual
Appreciate the help!
