Author Topic: SOLVED - Yet another stalling mystery  (Read 5038 times)
Re: Yet another stalling mystery
« Reply #15 on: June 19, 2014, 05:48:05 AM »
I just use a bit on my fingers, and smear it on the O rings. It sort of glues them in place during assembly.
The Temp. thing don't matter. What happens is if it is tooo hot for the sealant it liquefies which is actually what you want. I use it for everything on all types of engines.
Don't worry about Paying it forward/backward. Just post up some random sh**, and people will believe anything you say.
Thats how I got 10K posts....
MN_Scoot
« Reply #16 on: June 19, 2014, 06:30:22 AM »
Thanks man, for the feedback and for that very touching music video. sniff sniff.  ;D
2007 Kymco Agility 50
Stock other than Dr. Pulley Sliders and derestricted from the dealer.
« Reply #17 on: June 20, 2014, 02:06:12 AM »
LOL. I forgot I posted that.
This is much more appropriate...
MN_Scoot
« Reply #18 on: June 24, 2014, 03:44:47 PM »
Ugh! This problem is going to be the end of me.
Over the weekend, I took off the intake, lightly sanded the spacer, put in new o-rings in the spacer and intake and went to a friends house about 20 miles away. Thought everything was great until about mile 15, I hit a hill and it started doing the lose power and stall out thing (I usually feel a slight surge or two while this happens). I let it sit for a minute os so, did the full throttle start (as you would for flooded engines) and it started up again. It again stalled out 2 more times in the last 5 miles.
Going home was fine uphill or whatever for the first 10-15 miles, then it stalled again.
Glad I replaced the o-rings b/c I think they still needed it. Was about to order a new carb, then I read a bunch of forum posts where people stalled after quite a few miles/hills and it keeps pointing to valve adjustment. Sound right?
I just adjusted them about 300 miles ago, so was ruling that out, but maybe I was off a little…used the .04mm feeler gauge.
Any other ideas/things I should check while I'm in there and before I seal it all up again?
« Reply #19 on: June 24, 2014, 05:53:53 PM »
Did you ever check the auto choke?
I have also had a bad petcock that was dumping fuel into the vacuum line. The petcock is like 9 bucks at partsforscooters,com There are a few different ones so be sure to order the correct one
MN_Scoot
« Reply #20 on: June 24, 2014, 06:03:38 PM »
I tried by just measuring with the ignition turned to on and there was no movement at all for the total 6 minutes. Do I have to hook to the battery directly?
I also could not do the resistance test because I could not get to the choke's plug end without taking off my rear body panels since it was so far tucked back which I didn't have time for that day.
« Reply #21 on: June 24, 2014, 07:28:26 PM »
That may be your entire problem then.
 You can order a new choke on ebay or partsforscooters.com It's just a few bucks. Make sure you have 12 volts going to it first... A test light will do because the resistance check wont tell you anything. That pin MUST move 4mm or better otherwise it is constantly flooding. The warmer the engine gets the more the flooding is affecting it.
MN_Scoot
« Reply #22 on: June 24, 2014, 07:50:06 PM »
Hmm, ok. I just didn't know if only turning the key to "on" was sufficient…read elsewhere that people were hooking the plug of the choke directly to the battery. Do you know if the way I tested would be sufficient? -I assumed testing with the scoot actually running would make gas spurt from the port I just pulled the choke out of. Sorry for the newb questions.
« Reply #23 on: June 24, 2014, 07:55:35 PM »
Just pull out the choke, and turn on the key. IF it is getting power it will move the pin slowly. The only reason to hook it direct to the battery is if there is NO power to the choke, and you need to verify it is working.
Even if it is moving you want to be SURE it moves at least 4mm.
MN_Scoot
« Reply #24 on: June 29, 2014, 12:13:14 AM »
New pieces to the puzzle...I just opened it up again after letting it sit immediately after the last stall out which happened again at WOT.
The plug was pretty white and the fuel filter was empty. Will check the valves again shortly, but does this rule out a choke problem? I can't get to the choke plug without taking off the body panels...I'm just getting sick of removing and replacing those panels every time something goes wrong  :-\
Does the empty fuel filter point to a petcock or vacuum issue?
« Reply #25 on: June 29, 2014, 02:59:28 AM »
To your last question YES.
A white plug means it is running too lean. New guess is either a leaking vacuum line, a bad petcock, or a clogged up fuel screen in the tank. Easiest solution is order a new petcock, and some vacuum tubing.
Pull the screen out of the tank. Be sure it is clean, and replace the petcock, and vacuum line. They are all cheap parts, and you might just find it is a loose or worn thru vacuum line but having the petcock on hand for when it does fail will be a blessing.
I feel your pain on the plastics. One of my bikes has none. I tore them all off for the very reason you stated., and ride it as a bare frame. The second bike I fiberglassed all the plastics together into a one piece shell that simply lifts off. You can do without a lot of the screws that hold yours together, and Zip Ties make for a perfect quick connect system for broken tabs. Just drill matching holes. No one ever see's them if you do it right.
MN_Scoot
« Reply #26 on: June 29, 2014, 09:13:15 PM »
Thanks Zombie,
Will order some parts today. Was hoping to avoid buying a new carburator, but I'm getting so tired of weekly break-downs, I'm thinking of ordering a new carb as well to hopefully be done with this. Pretty soon, I'll have a brand new scoot I built piece by piece!  ???
Another puzzle piece, I just disconnected the hose going to the intake at the T and sucked on the end of the T and I couldn't suck air through it.
Couple of follow-up questions to your post...How do you get to/clean the in tank fuel filter you mention? I checked youtube, these forums and the service manual, but couldn't find instructions.
Also, do you need to use that white thread seal tape or anything when attaching a new petcock to avoid leaks?
Thanks again!
« Reply #27 on: June 29, 2014, 09:24:13 PM »
If you can't suck air it is pretty sure but not positive you don't have a vacuum leak. I'd replace the vacuum line anyway. Inside the petcock is a diaphragm that can jam up. Sometimes it jams just enough to partly block fuel, and make for lean running.
When you replace it do NOT use teflon tape. There is a pretty thick rubber washer that seals it up. When you remove the petcock thew washer will usually be stuck in the tank side. Use a tiny screw driver or whatever to pull it out. Same thing for the tank screen. It is pushed up inside the tank. Just pull it down/out w/ whatever tool you have.
MN_Scoot
« Reply #28 on: June 29, 2014, 09:53:09 PM »
Cool, yeah, I will replace all the lines to help rule everything out.
Was looking for new petcocks online. I saw in an older post you recommended partsforscooters.com for petcocks. I looked and they all seem to be in the 150cc pages. This was the closest in resemblance to what I have, but again, in the 150cc pages. Does this looks like it would work for a 50cc Agility? http://www.partsforscooters.com/129-25_Bolt-on_Fuel_Valve
...Or should I go to the dealer and pay big bucks to be sure it's correct?
Thanks man!
« Reply #29 on: June 30, 2014, 12:52:14 AM »
I have perhaps 6-7 petcocks that don't fit anything. The thread sizes are all different on these stupid things.
QAs I recall I called PFS, and the girl on the line was the biggest help in knowing which one fit.
I think the one you linked is correct. Kymco does NOT use larger petcocks until you get to the 250cc bikes.
Point is I would call, and ask. If there is still a doubt order two, and join the "We have many petcocks" club. (WHMP). Meetings Mon., and Fri. Ramada Inn, Crawfordville.
In case you are interested the Dark Side meetings are Tues., and Thurs. but you have to bring treats. Most of us like cup cakes or Taffy.
