Did you miss your
activation email
Technical | How To
SOLVED - Yet another stalling mystery
Pages:
3
Topic: SOLVED - Yet another stalling mystery (Read 4997 times)
Carter Merz
Re: Yet another stalling mystery
Reply #30 on:
June 30, 2014, 12:56:18 AM »
Most bikes won't turn the choke off just by turning the key in. To test reliably take the by starter out and hook up to a battery work alligator clips. Should extend all the way in like a minute or two.
MN_Scoot
Full Member
Re: SOLVED - Yet another stalling mystery
Reply #31 on:
August 05, 2014, 03:00:30 PM »
SOLVED: I readjusted the valves (they were just a little loose so probably a red herring), changed the fuel line and changed the petcock and no more stalling!
To add to the knowledge base, here is the petcock/fuel valve switch that fit my 2007 50cc Agility:
http://www.partsforscooters.com/164-93_Bolt-on_FUel_Valve
Thanks again everybody for all the help. Even when I didn't hit the problem, I preemptively replaced some stuff that needed replacing soon.
2007 Kymco Agility 50
Stock other than Dr. Pulley Sliders and derestricted from the dealer.
Back
