Author Topic: mxu 250 engine cutting out  (Read 2343 times)
fred pierce
« on: June 16, 2014, 08:58:57 PM »
my 2005 mxu 250 cuts out when i  try to rev the engine.
any body got any ideas of hat could be the cause
Re: mxu 250 engine cutting out
« Reply #1 on: June 16, 2014, 09:52:14 PM »
Details.... When did it start? When was the bike last serviced? How did it start?
How many miles on the bike? Original owner?
What are you wearing? ;)
fred pierce
« Reply #2 on: June 17, 2014, 05:55:04 AM »
Thanks for coming back to me
The quad has covered 3800 Klms and needs a service oil change etc the problem started when I was riding it just cut out . The quad starts and runs but when applying gas it cuts out ???
Yours faithfully
Fred
« Reply #3 on: June 18, 2014, 02:04:25 AM »
I would pull the top off the carb, and check that rubber diaphragm for tears Next I would pull off the float bowl, and look for dirt/anything up in the main jet.
Also pull off the vacuum line that goes to the fuel petcock. Suck on the end of the line, and you should have a steady stream of fuel out of the tank.
Could be as simple as a bad spark plug but I think the above stuff may get it.
fred pierce
« Reply #4 on: June 19, 2014, 06:54:39 AM »
Hi thanks for the info
Will take your advise and look at what you suggested many thanks
Fred
« Reply #5 on: June 20, 2014, 01:10:25 AM »
No trouble. Please keep us posted on what you find.
bism45
« Reply #6 on: June 21, 2014, 08:17:33 PM »
i have exactly the same problem on mine (same year) but i have 4 x mxu's and only this prob on one, i have cleaned the carb and they have quite new plugs, will def try the other ideas out though....cheers ;0
P.S YOU DIDN'T ANSWER WHAT YOU WERE WEARING LOL
« Reply #7 on: June 22, 2014, 05:48:17 AM »
No one ever does... Sigh
m2yuout
« Reply #8 on: January 18, 2016, 08:16:24 PM »
Similar issues here..... did you guys find the route cause??
Cheers
Bratman2
« Reply #9 on: January 19, 2016, 02:23:09 AM »
Last time I had this problem, grandson's Mongoose 90, the nearly new NGK plug was bad. Plugs are pretty cheap and fairly easy to change. I would do that first. Second I would tear into the carb if the plug doesn't fix it.
2019 UXV 700i LE Hunter
2014 MXU 450i
2004 Mongoose 90 (grandson's)
2010 Grizzly 450
