Did you miss your
activation email
Scooters - 50cc
gas gauge
Topic: gas gauge (Read 938 times)
gas gauge
June 18, 2014, 01:20:05 AM »
Wanting to try to fix gas gauge.does any one know what wires go wear down by the battery.I have one extra hot wire but not sure if thats it.
You never know do ya!
Close enough to get the idea!
Re: gas gauge
June 18, 2014, 02:09:30 AM »
All these bikes have a few extra dead end wires... Most times simply pulling out the sender, and cleaning the metal ring/tank connection fixes it. They work on a resistance to ground, and that mounting ring is the only contact
Re: gas gauge
June 18, 2014, 02:27:35 AM »
I dont think I have it hooked up because I never did after my gy6 swap. I can see yellow green and blue comeing from the tank going in to a plug thats 2 ,green and 1 yellow.from there im not sure.
Re: gas gauge
Reply #3 on:
June 18, 2014, 02:31:31 AM »
The manual will have it. Why would you have un pluged it?
I can't even look at mine for you. I threw out the harness, and made my own. No gas gauge.
Re: gas gauge
Reply #4 on:
June 18, 2014, 03:07:56 AM »
When I did the swap I was trying to use a gy6 harnes but did not work.so went back to the kymco harnes and stator.
Re: gas gauge
Reply #5 on:
June 18, 2014, 05:31:16 AM »
Got ya... The harness is broken down in the manual.
If I get a chance today I will run by the shop where the ZX dash is, and see what color is on the gauge.
I'm working out of three different shops, and I have stuff scattered between all of them.
Re: gas gauge
Reply #6 on:
June 19, 2014, 11:06:55 AM »
Ended up takeing gauge out of tank and cleaning it and nothing. So I took the gauge out of tank and run with out.made a plastic cover for the hole.
Back
