Author Topic: camshaft timing problem.. helpppp.!!  (Read 2056 times)
sunjejin
« on: June 22, 2014, 01:49:15 PM »
does anybody knows how to fix this? when i tried to parallel the two holes in sprocket my timing on flywheel not to center "T" alignment
DMblues01
  • 2012 Kymco Super 8 150
Re: camshaft timing problem.. helpppp.!!
« Reply #1 on: June 22, 2014, 03:27:13 PM »
You need to rotate the engine another revolution. the marks on the sprocket should have 3 holes showing. the 2 that line up with the edge of the engine, and 1 straight out in the middle. Then the timing mark should line up as well.
Roxana, IL
Yoda is my spiritual leader.
sunjejin
« Reply #2 on: June 22, 2014, 04:16:14 PM »
Thanks for your answer DMblues01 I set my valve clearance in this position, Is there any risk factor can damage my valve?. coz I depend my decision in "T" mark allignment in Flywheel but I think also it should be all set in right timing position, tommorow I set again..
« Reply #3 on: June 22, 2014, 04:50:55 PM »
Yes, the valves are not set correctly if you adjusted then like this. May cruise damage. Don't even look at the flywheel mark. Just make the two can dots level with the head and the large dot facing forward.
