Did you miss your
activation email
Scooters - 50cc
Like 50 2T
pilot jet
Topic: pilot jet (Read 2616 times)
netspeedo
Newbie
pilot jet
June 24, 2014, 09:54:37 AM »
Does anyone know what the stock size of the pilot jet for like 50 2t. Also where to buy a upsize thanks
2011 like50 2t
tecnigas q-tre exaust
101 octane cone air filter
stock carb 100 main jet stock 35 pilot jet
molassi variator
8g dr. Pulley sliders
1000 rpm tourque spring
245luigi
Sr. Member
Boston, MA
Re: pilot jet
June 24, 2014, 12:31:35 PM »
Should be a 35 jet
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
245luigi
Sr. Member
Boston, MA
Re: pilot jet
June 24, 2014, 02:05:55 PM »
http://www.kymcoforum.com/index.php?topic=9345.msg104271#msg104271
Currently:
2012 Kymco Like70
72cc Malossi BBK
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
Tecnigas Triops
netspeedo
Newbie
Re: pilot jet
Reply #3 on:
June 24, 2014, 09:26:59 PM »
Thanks I think im all ready just waiting for my delivery from racing planet. Comming from there European warehouse it has been two and a half weeks hope it shows up in us soon
2011 like50 2t
molassi variator
You never know do ya!
Close enough to get the idea!
Re: pilot jet
Reply #4 on:
June 24, 2014, 09:30:18 PM »
What did you order?
We NEED TO KNOW!
Just the Jets?
netspeedo
Newbie
Re: pilot jet
Reply #5 on:
June 24, 2014, 10:50:52 PM »
86-100 main jet, tecnigas q-tre exaust, 1500 naruku clutch, 1500 torque spring, torque driver, cone filter
2011 like50 2t
molassi variator
Re: pilot jet
Reply #6 on:
June 25, 2014, 05:03:49 AM »
Cool deal. I'd set up the pipe/air filter/jetting first. Ride it around for the day, and get a feel for it before you get into the cvt.
If there are any problems it is easier to figure them out this way.
netspeedo
Newbie
Re: pilot jet
Reply #7 on:
June 25, 2014, 04:05:18 PM »
Why would it matter if I did cvt first or pipe and jet first
2011 like50 2t
molassi variator
netspeedo
Newbie
Re: pilot jet
Reply #8 on:
June 25, 2014, 04:28:19 PM »
I use the scoot all weekend so I know I can bust out cvt. Then I was going to work on pipe during the week next week
2011 like50 2t
molassi variator
Re: pilot jet
Reply #9 on:
June 25, 2014, 04:46:06 PM »
the issue there is once you select the springs, and rollers you like, all that will change once you install the pipe.
The pipe/filter will change the power band of the engine making it perform differently. You have to tune the cvt to work with the power band.
If you tune the cvt first you will have to re-tune it after you install the pipe. Not a big deal if you enjoy changing things twice. I hate doing things twice. (puff puff pass doesn't count)
netspeedo
Newbie
Re: pilot jet
Reply #10 on:
June 25, 2014, 05:44:30 PM »
I was just guessing that is the setup I will like withe pipe. From reading other posts and setups similar seems like it will suit my needs with the pipe. Taking a chance I dont mind dicking with the cvt its the carb adjustments I want to do once.
2011 like50 2t
molassi variator
Back
