The easiest way is to install a "T" fitting on the vacuum line going to the fuel petcock. Start the bike, and you should see a steady reading of 20"hg.
Rev the bike to approx 3k rpm, and hold it there. The gauge should drop when you raise the rpm, and again hold steady when the rpm are steady.
If it is lower than 18ish you have a leak somewhere. same for a fluctuating reading. Vacuum leak.
