Author Topic: need fast idle help  (Read 786 times)
ifican
need fast idle help
« on: June 26, 2014, 03:16:00 PM »
Carb now fixed but no more fast idle. I had carb completely apart at one point, basically all screws and jets out. I most probably missed getting something set back to where it needs to be and cannot find in maintenance doc what to check. What can effect fast idle so i can figure out where its off. Outside of fast idle it starts and runs great. Only side effect is it idles a bit off until warm.
Re: need fast idle help
« Reply #1 on: June 26, 2014, 04:35:03 PM »
It sounds like you forgot to plug in the auto choke, or the connection has failed. Check for 12 volts on the choke side of the connector.
ifican
« Reply #2 on: July 08, 2014, 03:19:03 PM »
New i hadnt forgot wires but this was the fix. When i finally got a moment to look, the posts were plugged in but about 12 inches down the harness there are quick disconnects. Have no idea why they are there and had not seen them previously, but 1 side had come off. After plugging back in we are good to go. Thx for the idea......
« Reply #3 on: July 09, 2014, 05:03:34 AM »
You're welcome!
