Author Topic: Increasing performance on 2012 super 8  (Read 17985 times)
Re: Increasing performance on 2012 super 8
« Reply #30 on: July 09, 2014, 01:58:02 AM »
Stock rollers are 16x13, I run 35 / 30 psi on the bet and win. 40/ 35. With my zuma. With contrast springs, you only want to go as tight as needed, any tighter and you will decrease belt life and actually top speed too
« Reply #31 on: July 09, 2014, 03:45:34 AM »
This thread is driving me f'n nutz...
The yellow spring is weaker than the OEM spring in a 4t OEM clutch. Get a Purple Malossi (1500) or a red Malossi (2000)
If you are around 150LBS then the purple, and 7gr Dr. Pulleys. If you are closer to 200LBS go red, and 7-8 gr Dr. Pulleys.
Belt wear is subjective... Depends on how you ride. Tighter cvt parts do wear the belt faster but I generally get 2-3 belts a year. I ride20-30 miles a day/everyday so you can do the math.
I am also a HUGE fan of maximum tire pressure labels. B&L is correct that the tire can hold A LOT more than the Max. label but I can drink A LOT more than a liter of Whiskey. Neither of these are good IMHO>
All better now. Love you guys!
Chris0381
« Reply #32 on: July 09, 2014, 03:57:31 AM »
But I dont think either of us has the 4t. We are senior citizens, WE ARE ALL CONFUSED!!!!!!!
I would like to try a stiffer contra spring but dont know which one to get, and if I do try a stiffer contra spring for hill climbing, do I need to get heavier rollers to counteract the additional spring stiffness as I dont know what weight rollers I have presently on the stock variator.
I weigh 160 lbs pre beer guzzling.
2013 super 8 50 cc 2t 800 miles on OD
« Last Edit: July 09, 2014, 04:05:01 AM by Chris0381 »
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
« Reply #33 on: July 09, 2014, 04:21:42 AM »
Get the Phrlsiwnd or the Rsl IF YOU weigh 834- 917krz.
Use Ht. Pisjeec 0ed OR Ge. Jqllxb 1jf
« Reply #34 on: July 09, 2014, 07:19:57 AM »
Get both, cheap enough and you'll use both sooner or later. A stiffer spring with the same weights as a soft spring will rev higher, and with no other real mods will rev too high really fast. Your peak power stock is 7-8000rpm. Red spring with stock 8.5g will be revving to 8k rpm almost always right over your power band. Parts like exhaust and 70cc will enjoy revving higher.
Chris0381
« Reply #35 on: July 09, 2014, 01:11:38 PM »
Let me ask,
Is it for certain that the yellow 1500 spring is same or less than what is on there stock now for 2013 S8 50CC 2T ?
Throwing a dart, what would be a good initial gram weight and spring compression value to try with my setup as is? Goal to get a little better uphill performance.
I am considering 9 gm weights and a White Spring as my first guess as thats what one of the Malossi Kits has for the S8. My thought is they wouldnt provide a weaker spring than stock but if its for racing I'M GUESSING THEY COULD.
« Last Edit: July 09, 2014, 01:44:23 PM by Chris0381 »
Smooth Boss
Polini Variator
#95 Main Jet
« Reply #36 on: July 09, 2014, 06:41:40 PM »
Let me ask,
I don't have any idea how many times this has been said....
Malossi red, and 7-8gr Dr. pulley if you are 200lbs
Malossi Purple, and Dr. pulley 7-8 if you are closer to 150lbs
I have a shop FULL of springs/sliders/rollers. Perhaps 250-300 of them. Different makes/rates, and weights.
The above two combinations are the best for every brand scooter or engine type in 50cc to 100cc BBK's.
Spanish:
No tengo idea de cuántas veces esto se ha dicho ....
Rojo Malossi y 7-8gr Dr. polea si usted es 200 libras
Malossi púrpura, y el Dr. polea 7-8 si está más cerca de £ 150
Tengo una tienda llena de resortes / deslizadores / rodillos. Tal vez 250-300 de ellos. Diferentes marcas / tipos y pesos.
Las dos combinaciones anteriores son los mejores para cada scooter de marca o tipo de motor de 50cc a 100cc de BBK.
Gaelic:
Ní dóigh liom go bhfuil aon smaoineamh cé mhéad uair tá sé seo ráite ....
Malossi dearg, agus 7-8gr Dr ulóige má tá tú £ 200
Malossi Corcra, agus an Dr ulóige 7-8 má tá tú níos gaire do £ 150
Tá mé siopa IOMLÁN Springs / Barraí Sleamhnáin / rollóirí. B'fhéidir 250-300 acu. Dhéanann éagsúla / rátaí, agus meáchain.
Is iad an dá thuas teaglamaí is fearr do gach scútar branda nó cineál-inneall 50cc go 100cc i BBK ar.
German:
ch habe keine Ahnung, wie oft dies gesagt wurde ....
Malossi rot, und 7-8gr Dr. Riemenscheibe, wenn Sie 200 £ sind
Malossi Lila, und Dr. Scheibe 7-8, wenn Sie näher an 150 £ sind
Ich habe einen Laden voller Federn / Gleiter / Rollen. Vielleicht 250-300 von ihnen. Verschiedene Marken / Raten und Gewichten.
Die beiden oben genannten Kombinationen sind die besten für jede Marke Roller oder Motortyp in 50cc bis 100cc BBK.
Italian:
Non ho alcuna idea di quante volte questo è stato detto ....
Malossi rosso, e 7-8gr Dr. puleggia se siete £ 200
Malossi Viola, e il dottor puleggia 7-8 se sei più vicino a 150 £
Ho un negozio pieno di molle / cursori / rulli. Forse 250-300 di loro. Diverse marche / tariffe, e pesi.
I suddetti due combinazioni sono i migliori per ogni scooter marca o tipo di motore a 50cc a 100cc BBK di.
Czeck:
Nemám ponětí, kolikrát to bylo řečeno ....
Malossi červený, a 7-8gr Dr. kladka, pokud jste 200 liber
Malossi Purple, a Dr. kladka 7-8, pokud jste blíže k 150 liber
Mám obchod plný Springs / slidery / válečky. Možná, že 250-300 z nich. Různých značek / ceny a váhy.
Oba výše uvedené kombinace jsou nejlepší pro všechny značky skútr nebo typu motoru od 50 ccm do 100 ccm v BBK
Thai:
ผมไม่ได้มีความคิดกี่ครั้งนี้ได้รับการกล่าวว่า ....
Malossi สีแดงและ 7-8gr ดร. ลูกรอกถ้าคุณเป็น£ 200
Malossi สีม่วงและ ดร. ลูกรอก 7-8 ถ้าคุณมีความใกล้ชิดกับ£ 150
ฉันมีร้านเต็มจำนวนของสปริง / เลื่อน / ลูกกลิ้ง บางที 250-300 ของพวกเขา ทำให้แตกต่างกัน / อัตราและน้ำหนัก
ข้างต้นทั้งสองชุดที่ดีที่สุดสำหรับทุกสกูตเตอร์ยี่ห้อหรือชนิดของเครื่องยนต์ใน 50cc เพื่อ 100cc BBK ของ
Jibberish:
jdewjuj ji4jk f s   eiuisre   siifjjsxkjkje ozooe
keke rjfd sori wsoiw8irjgf  sooreor d sdoosr998
H s d kiioeloe riiiiao zjckjio99rif   cdkdkoikkdkdllgkj dditg d diutipoopsd sdiuiudo9809sa[p nhsozo
 sdjjk fiodktrki vhjBBK
Get whatever you want, and let us know how it works out. We are all here to learn.
« Last Edit: July 09, 2014, 06:51:06 PM by zombie »
Chris0381
« Reply #37 on: July 10, 2014, 11:55:24 AM »
Dang that's still low, go 40 in the rear and 35 front to gain even more speed. Also yes sliders will help with stock, but you'll want to get 7-8 g especially if you plan to get a stiff contrast spring. Stiffer spring = heavier weights to pull through that spring.
I got about a 1 MPH gain from this last night. How ever so slight addition to top speed, it also decrease the rolling resistance and seemed to make the transition from a flat to a hill smoother with less initial loss of speed. I have a lot of hills where I live and this little performance increase helps a bit.
Just ordered a Joes Racing Tire Gage for $24 off ebay. http://toolguyd.com/joes-racing-tire-pressure-gauge-review/ About time I repalaced my 30 year old one.
Still waiting on the #86 jet to arrive and presently running 3/4 turns out on the air screw, real nice ride last night.
« Last Edit: July 10, 2014, 01:08:15 PM by Chris0381 »
Smooth Boss
Polini Variator
#95 Main Jet
gnvernon
  • 2012 Kymco Super8 2T
« Reply #38 on: July 10, 2014, 01:53:19 PM »
Zombie I have seen everywhere online that the YELLOW spring is 1500 and that red is indeed 2000. I also dont want to rev over my power band.
Also, Chris I believe the white is even softer than stock. If you did that and increased your roller weight I dont think you would even make it up a hill lol.
Chris0381
« Reply #39 on: July 10, 2014, 02:44:06 PM »
What is confusing me is that you read that if you increase your contra spring compression value, your supposed to be increasing your roller weights. So is going to a Malossi Purple a smaller compression value or greater value? as new Dr Pulley 8 gm rollers are less weight than the stock 8.5 gm rollers.?
My assumption then would be that the 8.5 stock rollers are a bit heavy for this bike to begin with and could be restricting it a touch or the purple spring hasa lessor compression value that the stock spring since lighter rollers are recommended.
« Last Edit: July 10, 2014, 03:16:15 PM by Chris0381 »
Smooth Boss
Polini Variator
#95 Main Jet
« Reply #40 on: July 10, 2014, 03:11:58 PM »
I think your over thinking it. You have to try one and see how you like it.
Chris0381
« Reply #41 on: July 10, 2014, 03:17:42 PM »
Yea I agree. I'll throw on a spring and see how its performance is then go form there and then exchange rollers around the spring. The purple is a bit hard to find here in the states as its mainly on Ebay in the UK etc.
Smooth Boss
Polini Variator
#95 Main Jet
« Reply #42 on: July 10, 2014, 03:20:31 PM »
Exactly, just don't go with the super tight during right away, start with medium. I'd you order your weights heavy maybe get 9g then use a scale and dremell to lighten them perfectly. Just evenly grind off brass from the inside.
Chris0381
« Reply #43 on: July 10, 2014, 03:31:18 PM »
Thanks Bettin, I'l lgo that route. I dont expect the change to be drastic.
Maybe Zombie can hook me up with a scale :)
Smooth Boss
Polini Variator
#95 Main Jet
gnvernon
« Reply #44 on: July 10, 2014, 04:00:21 PM »
any headshop will have a scale for $5 or less. They are also super cheap on amazon
