Author Topic: resetting the oil light.  (Read 4148 times)
houndguy
  • Fear the mangy mutt!
  • Your idiotism amuses me.
    • Scooter Revolution!
« on: June 27, 2014, 04:43:35 PM »
I'm sure it's here someone and I can't find my owners manual.   :'(
I changed the oil and can't reset the oil change light.
Little help here folks?
Just another scooter blog - http://www.2smallerwheels.blogspot.com
Re: resetting the oil light.
« Reply #1 on: June 27, 2014, 08:33:34 PM »
I "googled" the 500i and the owner's manuals say there is a button on the panel, right hand side, that says, "OIL SERVICE" and one should press it for 2 seconds to reset the oil service light. Now I have seen many of your posts and you would not have missed this with or without an owner's manual. So Kymco made a change in the setup since these pdf manuals were posted and yours is different. I do not have a 500i but I do have a DT300i and ya gotta push two buttons to reset the oil odometer which turns on the oil light.  I may be able to figure this out if I could see a picture of your instrument panel.
« Reply #2 on: June 27, 2014, 09:23:52 PM »
switch it to service and push the two buttons at the same time and hold it till it changes,.  should be the same as the downtown
houndguy
« Reply #3 on: June 29, 2014, 11:39:17 AM »
Still nothing.  This is the 08 model Xciting 500.  I know there is a way...I've done it before.
speedee86
  • 2012 Kymco Xciting 500 RI ABS
« Reply #4 on: July 02, 2014, 02:39:46 PM »
i know on my 2012, i believe its the top right button on the dash, says service or something, its a recessed button, i have to use a pen and push it in and hold for a little bit and it resets the service light. i would imagine it should be the same on yours, dont quote me on that though.
always leave yourself an exit incase you get stuck in a pinch. RIDE SAFE!
kymcorider
« Reply #5 on: July 20, 2014, 03:26:17 AM »
Good Grief, I guess I'm blind. I've been trying to get my "oil service" light off also. Now I see a button right side of dash to push. Hell to get old.
Ride on, Kymcorider.
« Reply #6 on: July 20, 2014, 07:39:27 AM »
sissy mary
« Reply #7 on: July 23, 2014, 04:18:28 PM »
You have to push and hold the button down for a few seconds with key on until it go's off. I have to use a (retracted) ball point pen to be able to push the button down far enough. If button is not pushed down far enough the light will not go off. I retract the ball point as not to tear through the rubber of the button when i'm pushing down hard on the button. In the winter when rubber is cold and stiff, it is very hard to do. :-*
