Author Topic: Checking Oil Level  (Read 3571 times)
Vision
Checking Oil Level
« on: June 28, 2014, 05:59:47 PM »
It's strange that the owners manual never mentions the proper method for measuring oil. With the bike on center stand, you'll get two different readings depending on which wheel is touching the ground. It seems the bike is more level with the rear tire touching, so I use that. Some guys on youtube use the front tire.
What say you?
MaryK
Re: Checking Oil Level
« Reply #1 on: June 28, 2014, 09:22:06 PM »
with my GV250 scooter, the front wheel is the one that touches ground naturally, so that is how I read the dip stick.
scoot safely,
New Rider in 2010
2009 GrandVista 250
« Reply #2 on: June 28, 2014, 09:37:33 PM »
It's a TINY difference. Don't sweat the small stuff.
« Reply #3 on: June 29, 2014, 12:00:52 AM »
If you're like the Stig, you need to move several pounds of those tools and spare parts forward under your seat....the Front tire should be touching on level ground for safety's sake when starting the scoot.
The box of emergency Moon Pies & tuna sandwiches can stay where they are, not much weight there.
Just sayin'
Vision
« Reply #4 on: June 29, 2014, 11:20:27 PM »
Ok, another question. Why do oil change videos tell you to run the engine for a few minutes before an oil change? In doing so you're moving oil out of the bottom of the pan where it drains from.
Vision
« Reply #5 on: June 29, 2014, 11:21:32 PM »
Just sayin'
I want to be like The Stig. How do I become more like The Stig?
« Reply #6 on: June 29, 2014, 11:26:52 PM »
Front wheel, it's actually the reason why the rack says "5kg max" so the front wheel stays on the ground on the center stand. The reason to run the scoot before its to warn up the oil a bit, more will come out the thinner it is.
Vision
« Reply #7 on: June 30, 2014, 12:19:07 AM »
That's a big help. Thank you!
Some videos say after the change to run it a few minutes and check the oil level again. Does that make sense to you?
« Reply #8 on: June 30, 2014, 12:25:23 AM »
On larger engines with lots of oil ports... yes. On engines that have canister filters... yes.
On scooters no.
« Reply #9 on: July 03, 2014, 10:01:00 PM »
An environmental issue and health reminder:
A tuna sandwich with onion has a slightly longer 'under-seat-shelf-life' than without.
Even so, for the air breathers and tree huggers out there - do not go much past 2 weeks without checking on the sandwiches. Remember, it gets warm under there and it's dark. Great for cheese making - but , to paraphrase Colonel Hal Moore - "gets pretty sporty for tuna sandwiches!"
wkreps
« Reply #10 on: July 30, 2014, 03:53:27 PM »
Warming the oil is just to help it drain better.
Wayne
« Reply #11 on: August 03, 2014, 04:12:01 PM »
A small amount of oil will be in the cylinder head after starting and warming up the bike. Also like any liquid oil expands slightly when heated hence raising the level on the dipstick. Also after a change, if your scooter has an external oil filter you have to start it to fill that filter.
csor.zola
« Reply #12 on: August 21, 2014, 10:26:43 AM »
When the oil is warm becomes thinner. So it's easier to change it like that
