Did you miss your
activation email
Scooters - 125 to 300
People 250
Something leaking??
Pages:
Topic: Something leaking?? (Read 4459 times)
You never know do ya!
Close enough to get the idea!
Re: Something leaking??
Reply #15 on:
October 10, 2009, 10:25:51 PM »
ALOT of info. gets lost in the translation from whatever to english. I simply fill to the over flow. Sure is a bi**h though getting gear oil into a spider hole!
ispud
Sr. Member
Reply #16 on:
February 16, 2010, 07:12:11 PM »
It's still dripping - not all the time and not very much. I looked on the bottom of variator housing and there appears to be black soot coming out of 2 big cutouts in the bottom back - does air go through here to cool the thing? I am assuming the black grit I am seeing on the bottom and in my puddles is ground up belt - not sure what the fluid is. I am going to pull the cover when I get my new air filter and do a day of maintenance. The leaks are directly under these 2 rectangular opening in the rear bottom to the housing.
Plan on switching to synthetic oil this next change. Any comments?
Reply #17 on:
February 17, 2010, 01:57:55 AM »
Pull off the cvt cover. There is a leak in either your fuel sys/gear box/or something else wet! Can you post a pict.? My answer is purposely generic because it seems you know where the leak is. If it gas, you know what that is;
ispud
Sr. Member
Reply #18 on:
February 19, 2010, 10:47:08 PM »
I was doing some work on the scooter today so I thought I would pull the cover off. Turns out there is one bolt that is IMPOSSIBLE to get to, so I didn't get it off. I did loosen it enough for several drops of oil to come out the bottom - so I am pretty sure something is leaking in there - couldn't tell if it was gear oil or regular oil. I plan on taking it to the dealer as this should be covered by warranty - whatever it is.
Reply #19 on:
February 20, 2010, 12:16:01 AM »
No Doubt!
Back
